Blu Bot 1.0
Revision as of 20:53, 25 April 2015 by Blu Bot 1.0 (talk | contribs)
Blu Bot 1.0
The Blu Bot 1.0 is the creation of Professor Valamanesh's Design 3550 Materials and Processes 2015 Spring Semester Course. Team members include: Alex Abele, Tori Boggs, Joanna Celestine, Khanya Keswa, Bill Leonard, Bingyu (Sophia) Li, Carson Long, Jean Paul Pompeo, and Katie Schmiedicker.
The Blu Bot 1.0 is a derivative of the Prusa i3 3D Printer design by RepRap Core Developer Prusajr along with the earlier Prusa Mendel iterations (Prusa Mendel (iteration 1) and Prusa Mendel (iteration 2)).
History
Blu Bot 1.0 started: March 2015
Blu Bot 1.0 finished: April 2015
The course deadline required that the project be started early-to-mid March 2015, ending with the final presentation on April 30, 2015.
Ideation
Objectives
  • Fully Operational
  • Wire Management
  • Stable Structure
  • Unique Design
  • Functionality and Aesthetic Balance
Initial Concepts
Revision
Practicality
  • Plate moves up and down revised to plate moving forward and back
  • Viewing side windows
  • Hidden motors and rods
Final Concept File:Blu Bot 1.0 Final Concept Illustrator File.pdf
Physical Mock-up 1
Issues
  • Not enough space for larger components
  • Too small
  • Filament placement
  • Lack of cord management
Physical Mock-up 2
Issues
  • Extra bottom compartment
  • Wider side compartment
  • Chamfers
  • Filament place
  • Window cut outs
  • Vent cut outs
Integral Changes
  • Base structure
  • Cord management
  • Acrylic support plate
  • Power source in a bottom compartment (Isolates heat, easier to cool printer)
  • Extruder
Issues
  • Too small
Execution
  • 3D printed parts
  • 2 fried boards
  • Rough poles
  • Material issues
  • T-Joint engineering (have to CNC?)
Specifications
Box Frame
Plastic Parts (exc. Extruder)
Non-Printed Parts (approx.)
Cost
Controller Electronics
Printing Size
Motors
Frame Material
Frame Manufacture
Pro
Con
Materials
SainSmart Package List Amount
SainSmart RAMPS 1.4 1
SainSmart Mega 2560 R3 1
SainSmart A4988 Driver 5
SainSmart LCD 2004 with Controller 1
SainSmart SD Card Breakout for Ramps 1
SainSmart Cooler Fan for 3D Ramps 2
SainSmart Mechanical Endstop with Cable 6
SainSmart RAMPS 1.4 Wiring Cable 1
SainSmart Heatbed MK2b 1
Thermistor for Heatbed (100K ohm) 2
Borosilicate Glass 1
Aluminium Bed Mount Plate 1
NEMA 17 Stepper Motors Minebea Mill Robot RepRap Makerbot Prusa 3D Printer 5
Assembled J-head Hotend Nozzle 1
GT2 20T Aluminum Pulley 5
GT2 5M Timing Belt 1
USB Cable 1
Materials List Amount
Hillman Group 44997 M8 Metric Stainless Steel Fender Washers 12
608ZZ 8x22x7 Shielded Greased Miniature Ball Bearings 10
18-8 Stainless Steel Flat Washer, Plain Finish, Meets DIN 125, M3 Hole Size, 3.2mm ID, 7mm OD, 0.5mm Nominal Thickness 100
LM8UU Linear Bearings for 3D Printer, Prusa Mendel, reprap 12
5x11x5mm Ceramic Ball Bearing 1
BPB5015M12 Blower Fan 12V DC 2P 50mm 15mm 10" wire 2 pins connect 1 pc usa 1
1/4 x 12 x 24 Fluor Blue Acrylic 1
Aluminum Set Screw Rigid Shaft Coupling, w/o Kenway for 3/16" Diameter Shaft 2
Sintron 3D Printer Controller RAMPS 1.4 Arduino Mega Pololu Shield for Reprap Prusa Mendel Arduino Mega2560 1
PC4-M6 Pneumatic Straight Fitting for 4mm OD tubing M6 6mm Reprap 3D Printer 1
MK8 Drive Gear for Reprap extruder 5mm bore and 7mm Effective Dia Mk-8 1
Extruder
For Blubot 1.0, we used a variety of standard and modified printed parts. We initially planned to use Prusa I3 parts and a Bowden extruder, not realizing that the Bowden separates the hot end and the cold end of the extruder. This did not align with our design intention, and we found that overall the Prusa Mendel printed parts made for a better fit. We did end up modifying a few of the original Prusa I3 parts: all four z axis corners and all the y axis corners were modified to add a way to secure them to our frame. We changed our extruder to a direct drive hinged extruder modified the extruder head mount to accommodate our slightly larger extruder, and used a newer fan duct design J-Head direct drive extruder. We also added a head-cooling fan E3D J Head cooler with Part vents.
Sources
Markerbot Desktop Software
Megatronics 2.0
Prusa i3 Direct Drive Bowden Extruder
RAMPS 1.4 Assembly Guide
SAINSMART 3D Controller Kit for RepRap
Solid Utopia Firmware Guide
Still Extruding: Flats on a Stepper Motor
