Blu Bot 1.0
Blu Bot 1.0
The Blu Bot 1.0 is the creation of Professor Valamanesh's Design 3550 Materials and Processes 2015 Spring Semester Course. Team members include: Alex Abele, Tori Boggs, Joanna Celestine, Khanya Keswa, Bill Leonard, Bingyu (Sophia) Li, Carson Long, Jean Paul Pompeo, and Katie Schmiedicker.
The Blu Bot 1.0 is a derivative of the Prusa i3 3D Printer design by RepRap Core Developer Prusajr.
Specifications
Box Frame | |
Plastic Parts (exc. Extruder) | |
Non-Printed Parts (approx.) | |
Cost | |
Controller Electronics | |
Printing Size | |
Motors | |
Frame Material | |
Frame Manufacture | |
Pro | |
Con |
History
Blu Bot 1.0 started: March 2015
Blu Bot 1.0 finished: April 2015
The course deadline required that the project be started early-to-mid March 2015, ending with the final presentation on April 30, 2015.
Materials
SainSmart Package List | Amount |
SainSmart RAMPS 1.4 | 1 |
SainSmart Mega 2560 R3 | 1 |
SainSmart A4988 Driver | 5 |
SainSmart LCD 2004 with Controller | 1 |
SainSmart SD Card Breakout for Ramps | 1 |
SainSmart Cooler Fan for 3D Ramps | 2 |
SainSmart Mechanical Endstop with Cable | 6 |
SainSmart RAMPS 1.4 Wiring Cable | 1 |
SainSmart Heatbed MK2b | 1 |
Thermistor for Heatbed (100K ohm) | 2 |
Borosilicate Glass | 1 |
Aluminium Bed Mount Plate | 1 |
NEMA 17 Stepper Motors Minebea Mill Robot RepRap Makerbot Prusa 3D Printer | 5 |
Assembled J-head Hotend Nozzle | 1 |
GT2 20T Aluminum Pulley | 5 |
GT2 5M Timing Belt | 1 |
USB Cable | 1 |
Materials List | Amount |
Hillman Group 44997 M8 Metric Stainless Steel Fender Washers | 12 |
608ZZ 8x22x7 Shielded Greased Miniature Ball Bearings | 10 |
18-8 Stainless Steel Flat Washer, Plain Finish, Meets DIN 125, M3 Hole Size, 3.2mm ID, 7mm OD, 0.5mm Nominal Thickness | 100 |
LM8UU Linear Bearings for 3D Printer, Prusa Mendel, reprap | 12 |
5x11x5mm Ceramic Ball Bearing | 1 |
BPB5015M12 Blower Fan 12V DC 2P 50mm 15mm 10" wire 2 pins connect 1 pc usa | 1 |
1/4 x 12 x 24 Fluor Blue Acrylic | 1 |
Aluminum Set Screw Rigid Shaft Coupling, w/o Kenway for 3/16" Diameter Shaft | 2 |
Sintron 3D Printer Controller RAMPS 1.4 Arduino Mega Pololu Shield for Reprap Prusa Mendel Arduino Mega2560 | 1 |
PC4-M6 Pneumatic Straight Fitting for 4mm OD tubing M6 6mm Reprap 3D Printer | 1 |
MK8 Drive Gear for Reprap extruder 5mm bore and 7mm Effective Dia Mk-8 | 1 |
Sources
Prusa i3 Direct Drive Bowden Extruder
