BHead
Revision as of 09:30, 4 February 2013 by Balestrino (talk | contribs)
BHead
Release status: Experimental
BHead HotEnd
GPL
Introduction
BHead has been designed to have a extremely simple and reproducible design (you need only a lathe)
Is made of brass and PTFE or PEEK thermal barrier.
PEEK is the best choice. Anyway PTFE tube is inside the thermal barrier.
Advantages
  • Groovemount like J-Head
  • very strong and simple design
  • no fancy parts
  • easy of changing nozzle
  • heater cartridge 6mm (12V or 24V)
  • great heat tramission because heater block is like a clamp
Disadvantages
  • not yet found!
Compatible with
- Wade's and Greg's accessible extruder
- Printrbot Bowden Cable mod (http://www.thingiverse.com/thing:26963)
- Groovemount
- with all snap-in JHead extruder --- http://www.thingiverse.com/thing:27804 --- http://www.thingiverse.com/thing:29286 --- http://www.thingiverse.com/thing:42112 --- http://www.thingiverse.com/thing:39098
- GRRF extruder mount (http://www.thingiverse.com/thing:25035)
Suppliers
just contact me
Installation
Using the Mounting Holes in the Wade Extruder
Wade Extruder
  1. Insert the nozzle holder in the 5/8 inch (16mm) hot-end socket.
  2. Using a sharp instrument or other object, mark the 4 hole locations on the nozzle holder.
  3. Remove the nozzle holder.
  4. Using a round file, file the mounting grooves in the nozzle holder in order to create 2 grooves for the mounting screws or bolts to pass through.
  5. Install the hot end.
Using A Mounting Groove
Use a nozzle holder that is machined with the optional mounting groove and a cold-end that is designed for using a mounting groove or an adapter plate adapter plate for a mounting groove. In this configuration, a mounting groove is normally required.
