Aakar Motherboard
Revision as of 22:35, 24 November 2014 by Jitu9954 (talk | contribs)
Aakar Brainboard v2
Release Version 2.0
unknown
Aakar Brainboard v2 is a modular CNC controller board based on LPC1768 Cortex-M3 chip. Due to its modular design it allows easier upgrades as per requirements and easy replacement if there is any broken part. It runs on open source Smoothie modular firmware and is targeted at 3D Printers, Laser cutters, CNC Mills, Pick and Place and other small or Mid size CNC machines.
Note: design of the PCB layout is apparently missing, so it's only partially Open Source. --Traumflug (talk) 04:27, 25 October 2014 (PDT)
Aakar Brainboard V2
Features
Microcontroller
  • NXP LPC 1768 32-bits Cortex-M3 MCU, running at 100Mhz. 512kB Flash, 64kB RAM.
  • Drag and drop flashing : simply drop a new firmware file to the Aakar drive to update.
  • USB2 Composite device : shows to the computer as both a Serial device, and a Mass Storage device ( exposing the SD-card).
  • Ethernet.
Stepper drivers
  • 3 to 5 Allegro A4983 or DRV8825 stepper driver modules.
  • Each capable of driving bipolar steppers up to 35V and 2A(DRV8825).
  • Microstepping control of individual stepper to give greater flexibility.
Power outputs
  • Up to 3 through hole 10A, Mosfets sharing a power circuit.
  • Up to 2 Mosfets with options of regulated 12V output for Fans.
  • One Mosfet with separate power supply 20A, up to 36V.
  • One optically isolated DPDT relay ~240V,5A for driving AC loads like milling tools or vacuum pumps.
  • Regulated 5V and 12V headers.
Power inputs
  • Main 12-24V (Stepper drivers ) power can be connected using a 3.5mm or 5mm screw terminal
  • 5V input can be taken directly from the USB cable or supplied by a 5V switching regulator installed on the board.
Inputs
  • 4 Thermistor (12-bit ADC ) inputs.
  • 6 Endstop inputs.
  • Play/Pause LED and Button
  • Connector for Serial Graphic LCD Panel supported by smoothieware.
Extensibility
  • 1 SPI connector.
  • 1 SPI/UART connector.
  • 1 I2C connector with selectable 3.3V or 5V pull-ups.
  • 1 I2C/UART connector.
  • 1 UART connector FTDI cable compatible pinout.
  • All GPIO pins broken out on headers.
  • 4 LEDs, many connectivity options.
Firmware
  • Runs the highly-modular Smoothie firmware.
Design
  • Dimensions are 120x150mm.
Documentation
Power distribution
Aakar Brainboard v2 is designed to provide a flexible power input options to different modules. Below diagram shows distribution of input power. Distribution of power can be controlled by setting two solder jumpers provided on the underside of board.
Solder Jumper, SJ1:FAN_PWR
This jumper selects input power for FAN1 and FAN2 Mosfets. These are low power Mosfets used to power DC fans LED arrays(loads up to 5A) without heatsink.
12V position
In this position power is supplied form onboard 12V switching regulator that can supply up to 3A of current. It is useful when you want to drive a 12V fan but main power supply is greater than 12V.
  • NOTE: In this mode load current must not be greater than 3A. Driving loads greater then 3A will trigger over current protection.
VIN position
In this position input voltage (VIN) is directly supplied to these Mosfets. In this mode each mosfet can drive 5A of continuous current without any heat sink.
SJ2:HE_PWR_SEL
This jumper selects input power for HE1, HE2 and HE3 Mosfets. These mosfets can be used to drive extruder heaters with load current of 10A each with heatsink.
VIN position
In this position in this mode input voltage(VIN) is used to drive these Mosfets.
  • CAUTION: VIN can range from 12V to 24V, higher voltage will damage the board.
VHB position
In this position Mosfets are powered form voltage supplied at VHB terminal. In this position voltage can be in range12V-36V.
Heated Bed
Heated bed Mosfet is powered from HBIN terminal. Input voltage can be in range 12V-36V and current upto 20A. This supply also has option for a fuse in series using PAD1 and PAD2.
  • CAUTION: This Mosfet can get very hot during operation do not touch with bare hands.
Relay
An onboard optically isolated DPDT relay is provided which can be used to switch AC loads at 240V, 5A. Input AC voltage is applied at IN terminal and NO and NC outputs can be used as output.
  • NOTE: This is a mechanical relay so PWM is not possible and switching frequency must not exceed 10Hz to increase relay life (Pin compatible Solid State Relay can be used as replacement for PWM operation).
Stepper Motor power
Stepper motor are powered from reverse protected VIN supply. Steppers input power can range from 12V-24V. Remaining board is powered from on board 5V switching regulator.
End Stops Power
Endstops can be powered from 5V or 3.3V by setting END_STP_VCC jumper located underside of the board.
Stepper Motors
Aakar Brainboard v2 supports Pololu DRV8825, A4983 stepper modules(or any pin compatible module). Maximum 5 onboard modules can be used.
  • NOTE: Aakar Brainboard v2 can only support Bi-polar stepper motor operation. However, any uni-polar stepper motor can be used in bipolar mode
Stepper motors can be connected to the board using 3.5mm screw terminals or cheaper 2.54mm strip connectors. Microstepping can be set individually for each stepper motor by jumpers provided under each module.
Micostepping table
A4983 Module Jumper setting
DRV8825 Module jumper setting
Extensibility
SPI_1 Header
This SPI port is shared with SD card. Pin2 can be 3.3V or 5V powered by setting SPI1_2_VCC jumper.
SPI_2 Header
This Header can be configured as SPI port or A USART Port. Pin2 can be 3.3V or 5V powered by setting SPI_1_VCC jumper.
I2C_1
This I2C port can be interfaced with a 3.3V or 5V logic device, Pull ups are provided with either 3.3v or 5V pullups.
I2C_2
This Header can be configured as I2C port or a USART port.
  • NOTE: disable Pull-ups when using in USART mode.
SER_1
This header is pin compatible with FTDI cable. This serial port is used during SPI mode to flash bootloader.
GLCD Panel Header
ST7565 and ST7920 controller based Graphic LCD panels can be used. Encoder with a push button, a PLAY button and a RESET button is also supported.
More info about interfacing at: http://smoothieware.org/panel
Stepper motor Header
An extra stepper motor can be added to this Header.
  • NOTE: Motor supply Voltage is not supplied through this header. VCC_LOGIC is for logic supply only.
CPU Board
CPU board is the processing module of Aakar Brainboard v2. This Board has onboard mini USB port, RJ45 Ethernet port, micro SD card slot and 10-pin JTAG header.
  • NOTE:Onboard microSD card slot and SD card slot on Brainboard v2 share same pins ,only one can be used at a time and only one of them is populated on the shipped board.
ISP button is also provided on board to facilitate ISP flashing. This button can also be used as a user button by setting a jumper. More info about flashing bootloader to the board is available at smoothieware website.
  • NOTE: All boards comes preflashed with SD bootlaoder.If you want to flash other bootloader using ISP you need to set button jumper to ISP mode
Aakar Brainboard v2
Aakar Brainboard v2 3D printed Samples
Obtain fully assembled Aakar Brainboard v2
See[1] If link not working: Drop an email for price and other enquiry [email protected]
Reference Schematics
Aakar Brainboard v2 official manual:
200px
