User talk:Brupje
Hallo,
nachdem ich die Testsoftware geladen habe und mit Arduino 1.5.2. compilieren wollte kam die folgende Meldung.
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp: In function 'void spiSend(uint8_t)':
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp:35: error: 'SPI' was not declared in this scope
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp: In function 'uint8_t spiRec()':
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp:44: error: 'SPI' was not declared in this scope
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp: In member function 'uint8_t Sd2Card::init(uint8_t, uint8_t)':
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp:251: error: 'SPI' was not declared in this scope
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp: In member function 'uint8_t Sd2Card::setSckRate(uint8_t)':
/Applications/3D/Arduino.app/Contents/Resources/Java/libraries/SD/utility/Sd2Card.cpp:507: error: 'SPI' was not declared in this scope
Achtung ich arbeite unter Mac.
Für einen Tip wäre ich dankbar.
Gruß Benno
To fix; inside the .ino/.pde file, before the other includes, set the line:
#include <SPI.h>
Hi, I am using a megatronics v3.0 and experience some trouble aquiring temperatures with marlin. Can you please supply schematics (can only find some 2.0 files) or at least a verified pinouts list?
Thanks in advance!
Robs
