Rosalind-bill-of-materials
(Redirected from Rosalind bill-of-materials)
Bill of materials
Printed parts
- y axis clamps
- angle fasteners
Printer Frame
- Four pieces of T-slot aluminium profile length: 400.
- Eight pieces of T-slot aluminium profile length: 360.
Enclosure
- A sheet of acrylic 360 x 360Z x 3 mm (for the back).
- A piece of plywood 400 x 400 mm (for the bottom).
- 360 mm self-adhesive led strip.
Vitamins
Rods (usually steel)
- Two rods Φ8, length: 380.
- Two rods Φ8, length: 352.
- 2 (Two for now) rods Φ8, length: 390.
Bed
- Two pieces of 20 mm wide T-slot aluminium profile length: 250.
- 1 of 20 mm wide T-slot aluminium profile length: 133.97
- One piece of 2 mm thick glass, size: 214 mm x 214 mm.
- One piece of 5 mm thick wood size, size: 257.665 mm x 214 mm.
- One 12V pcb heating element, size: 214 mm x 214 mm.
- Two springs 0.8x6x20 (make sure the springs fit your bed screws; if you need to go bigger, go!).
- One 8 mm leadscrew of length 300 mm.
- One 8 mm leadscrew nut.
- Four bulldog clips thick enough to clamp 15 mm.
- One thermistor compatible with Marlin :electronics:
Visit the following link to check all supported thermistors https://github.com/MarlinFirmware/Marlin/blob/1.1.x/Marlin/Configuration.h#L261
Screws and Bolts
- Enough M5 in all lengths between 8 and 20mm (around 100 in total).
- Enough M3 in all lengths between 10 and 50mm (around 200 in total).
Rest
- Six 3 mm bore, gt2, timing idlers for 6mm belt width (20 teeth).
- Two 3 mm bore, gt2, timing idlers for 6mm belt width (toothless) or four 623zz flanged bearings.
- Two 5mm, gt2, timing pulley for 6 mm belt width (20 teeth).
- Two 5x8 mm flexible couplers.
- 4 LM8UU linear bearings or 1 of them if you use the long variant LMxLUU (z-axis).
- Four LM8UU (y-axis) (two for the long variant).
- Four LM8LUU (x-axis) (two for the long variant).
- One 608ZZ bearing.
- One extruder drive hobbed pulley MK8.
- 400 mm bowden (PTFE) tube.
- One brass PTFE tube push-fit connector.
- Three end-stop microswitches.
- One e3d extruder assembly.
- One 30Watt heating element.
- One 100K Ohm thermistor cartridge (semitec 104gt2).
- One 30mm fan.
- One heatsink.
- One aluminium heating block.
- One 0.3mm brass nozzle.
- One stainless steel heat break.
- One silicone sock.
- One 40mm, 12V fan.
Electronics
- One arduino MEGA (a small 8-bit, single-purpose computer).
- Four motor drivers.
- Three NEMA17 motors (minimum 20 Ncm torque).
- One NEMA17 motor (75Ncm torque) (this is for extruder drive, direct; for a geared extruder drives 40Ncm should be enough).
- One ramps shield.
- One LED power supply unit (12V).
- A USB extension cable (to connect the 3D printer to a computer).
- Cables* (we need lots. we need to research on required gauge. we will need all colors. - 22awg 0,34mm).
- 4pimN-4pinM cables for extension (enough, of sufficient length).
- 3pimN-3pinM cables for extension (enough, of sufficient length).
- 2pimN-2pinM cables for extension (enough, of sufficient length).
- One RePraDiscount smart controller.
Consumables
- A spool of PETG filament.
Improvements
- 24V power supply
- 2 mosfets
- one power plug
- one power switch
- one raspberry
- one camera
- one SD card
- a KVM (no redundant USB cable)
