RUG/Pennsylvania/State College/Razor Blade Designs
(Redirected from Razor Blade Designs)
Back to State College RepRap Main
POST DESIGNS HERE NOW!!!!
Task
To design a holder for replaceable razor blades. These blades could be either the standard rectangular shape or the standard trapezoidal shape, as shown below. The design needs to be able to be printed on the RepRap 3D printers we have in class.
Brian's razor blade holder design
I chose to design my handle for the trapezoidal blade. I felt that the tab geometries at the top would make it easier to hold the blade in place. I chose a sandwich style design where two halves squeeze the blade in place. The halves are secured with a machine screw that runs though the middle of the handle. Below is a Solidworks rendering of my design.
This handle was going to be printed on a RepRap printer; ones we are current having warping problems with. That is why there are tabs along the outside edges. This table help hold the first few layers to the print bed until they cool. The tabs are only a few millimeters thick but are connected to the model with only one layer of material. This way the tabs can be easily removed and the holder can be printed without fear of warping.
The two sides of the holder are not identical. There are a few features on the inner edges that cannot be seen in the picture above. There is an inset in one half that is just slightly larger than the features of the razor[1] blade. The blade sits in the inset loosely but there is a tab on the opposite half that squeezes against the blade and prevents it from moving. To ensure this tab is always applying a force on the blade, two long tabs and two slots are on the insides of the two halves. The slots are on one side and the tabs are on the other obviously. The height and depth of the tabs and the slots respectfully were picked so they wouldn't bottom out before the tab touches the blade. This not only ensure the blade will stay in place, but also ensure the halves will stay in place when the handle is held. They prevent the halves from rotating around the machine screw or translating up/down or left/right.
There is always a consideration for the about of material that is being used per part and the time it takes to print. That is why the end of the handle has triangular holes through it. The end of the handle is only meant to add comfort when the user grips it. Having something in the palm of your hand makes it easier to hold and easier to apply a larger force with the blade. But!, it is not critical for this part of the handle to be strong. It just needs to resist the pressure of the palm. The holes were put there because the material is not needed there and it would reduce the material used. This also means the print will take less time. If a printer tried to print that material, it would probably take at least 10% longer. The triangle and rectangle in the middle of the handle are there for the same reason. It would be more worth it to save time and material on the print that have the minimal structural benefits it would give.
In the center of the center of the part, there is a hole for a fastener. It is sized for a M3 machine screw. I added a washer to each side to prevent the screw from pushing into the plastic. I also added a wing nut so make it easier to secure the blade without the need of a wrench.
Instructions for printing
There are two halves that need to be printed. Be sure to open the STL files in a program like ReplacatorG to ensure that the part is oriented correctly and is in the center of the print bed. Although it is always good to conserve material and time, the structural integrity of the part needs to be considered. For this reason, be sure to increase the amount of outer shells of the print in Skeinforge or an equivalent Gcode generating software. I set the number of shells to 4. The reason for this is to make sure the sharp blade doesn't push though the solid plastic wall when the handle is being used. I did not use the handle a lot before I turned it in, but 4 shells seams to be solid enough to prevent blade from pushing through the part. I suppose it is good to be careful still, especially when pushing really hard on the blade. With 4 shells the infill ration only needs to be about .35 for it to be strong enough.
If your printer has a tendency to warp large flat objects, then hopefully the tabs will reduce this. Also, if this happens frequently to you, consider installing a heated print bed.
            • This design can be found here on Thingiverse.com [[2]] ******
Jon's Razor Blade Handle Design
This razor blade handle was designed with both printing simplicity and ease of use in mind. The part is comprised of just one STL file and can be printed in one sitting. The handle features a slot where a standard trapezoidal razor blade will slide into and be held in place by two set screws. The handle provides ergonomic comfort in addition to protection from the blade while in use.
When printed properly, the plastic printing layers oppose the cutting force of the blade, which makes this design very applicable for higher strength applications, provided that the handle printed well. Special consideration must be drawn to ensuring the handle is printed in the correct orientation because the plastic layer orientation will make the handle stronger and the triangular and trapezoidal holes in its body can only be printed in one direction. Please ensure that the STL file is placed in the vertical positioning as seen in the picture above.
This design can be found on Thingiverse.com. [[3]]
Mike's Razor
My razor design is made of two parts, a handle and the blade holder. The to parts have circles that mate with one another making the razor fold-able. This adds a level of safety to the design because the blade tip is covered when not in use. K1.png K2.png
