MKS CTR
Release status: Working
| Description | Anti-interference SDcard for 12864/2004LCD
| License | |
| Author | |
| Contributors | |
| Based-on | |
| Categories | |
| CAD Models | |
| External Link |
Overview
1.Reprap 2004LCD carries with SD card which is easy to get interference because of faster transmission rate when transfers data to main board by data line. That will inexplicably shut the machine down , or the print head run around etc .To reduce interference ,data line shielded with foil should connects to ground, while as short as possible .
2.MKS CTR can be directly connected to 2004LCD or 12864LCD, but effective SD card slot is an independent suit, so SD card slot on 2004LCD and 12864LCD is noneffective.
3.This is customized product which mainly solve the interference problem of SD card. If required, please tell us in advance .
Usage
1) Can be used directly on MKS Gen,MKS Base (V1.2 updated version ), MKS MINI.
2) If you use it on Ramps1.4, you need the L-shaped adapter board.
