Gen6 SD
Kliments SD Ramps works with Gen6.
This is how to connect the cables. [1]
And thats the pins: (taken form my currrently running Marlin FW) aresearchpaper.org
if MOTHERBOARD == 5 || MOTHERBOARD == 51
#define KNOWN_BOARD 1
#ifndef __AVR_ATmega644P__
#ifndef __AVR_ATmega1284P__
#error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
#endif
#endif
//x axis pins
#define X_STEP_PIN 15
#define X_DIR_PIN 18
#define X_ENABLE_PIN 19
#define X_MIN_PIN 20
#define X_MAX_PIN -1
//y axis pins
#define Y_STEP_PIN 23
#define Y_DIR_PIN 22
#define Y_ENABLE_PIN 24
#define Y_MIN_PIN 25
#define Y_MAX_PIN -1
//z axis pins
#define Z_STEP_PIN 27
#define Z_DIR_PIN 28
#define Z_ENABLE_PIN 29
#define Z_MIN_PIN 30
#define Z_MAX_PIN -1
//extruder pins
#define E0_STEP_PIN 4 //Edited @ EJE Electronics 20100715
#define E0_DIR_PIN 2 //Edited @ EJE Electronics 20100715
#define E0_ENABLE_PIN 3 //Added @ EJE Electronics 20100715
#define TEMP_0_PIN 5 //changed @ rkoeppl 20110410
#define TEMP_1_PIN -1 //changed @ rkoeppl 20110410
#define TEMP_2_PIN -1 //changed @ rkoeppl 20110410
#define HEATER_0_PIN 14 //changed @ rkoeppl 20110410
#define HEATER_1_PIN -1
#define HEATER_2_PIN -1
#if MOTHERBOARD == 5
#define HEATER_BED_PIN -1 //changed @ rkoeppl 20110410
#define TEMP_BED_PIN -1 //changed @ rkoeppl 20110410
#else
#define HEATER_BED_PIN 1 //changed @ rkoeppl 20110410
#define TEMP_BED_PIN 0 //changed @ rkoeppl 20110410
#endif
#define SDPOWER -1
#define SDSS 17
#define LED_PIN -1 //changed @ rkoeppl 20110410
#define FAN_PIN -1 //changed @ rkoeppl 20110410
#define PS_ON_PIN -1 //changed @ rkoeppl 20110410
#define KILL_PIN -1 //changed @ drakelive 20120830
//our pin for debugging.
#define DEBUG_PIN 0
//our RS485 pins
#define TX_ENABLE_PIN 12
#define RX_ENABLE_PIN 13
#endif
