FoldaRap PG35L
Back to the FoldaRap_Build_Manual
Don't forget to make a flat on the shaft if there isn't one, using a file
with a rubber roller
with a bearing and a bolt
PG35L.jpg x1 extruder motor (50cm) M3x12.jpg x2
FoldaRap extruder-idler2.jpg extruder-idler
(some early versions are using a rubber roller instead)
If your motor came with an aluminium gear, here is how I remove them (M4 bolt+hammer+vice) :
<videoflash>pT2zk--KqBo|320|240</videoflash>
<videoflash>XdfJH7XhZbk|320|240</videoflash>
Wiring
For the Pololu settings : 0.32 for the Vref
