FoldaRap2.6 Build Manual
FoldaRap Documentation
FoldaRap 2.6
Previous versions
The build manual for the previous versions are here :
Tools
Included tools
Tools to provide
Bonus tools
General tips
  • Read the whole manual before starting to get an overview of the building steps (total: 12 hours of assembly).
  • The FoldaRap is made of a base frame and several sub-assemblies. Some can be done in parallel to save time, gather your friends and establish a new building time record !
  • Work on a cutting mat if you have one: it will protect your table plus they often show a millimetre grid that can be useful to check the bolts length (with experience you will recognize them by looking or holding one).
  • Place your mouse over a picture to know the element name.
  • Do not hesitate to have a look at the 3D model in SketchUp (before/during the build): it will show you the folded/unfolded state of the machine and you can play around with it.
Printed parts
Lasercut parts
Use environment
  • Dry environment
  • Room temperature (between 5°C and 35°C)
  • Protected from dust
  • On flat surfaces
  • Protected from inflammable substances
  • Apart from other electronic devices
A use out of these conditions can damage your 3D-printer...
Insert a T-nut
Step 1/20 - Base Frame (30 min)
Foot-front-left.png x1 foot front left Foot-front-rightt.png x1 foot front right 20x20 200mm.jpg x2 200mm profile M4x8 round-head.jpg x4 M4x8 T-nut.jpg x4 T-nut
Foot-front-left.png x1 foot rear right Foot-front-rightt.png x1 foot rear left 20x20 200mm.jpg x2 200mm profile M4x8 round-head.jpg x4 M4x8 T-nut.jpg x4 T-nut
FR2-5-hinge-inner-left.png x1 hinge inner left FR2-5-hinge-inner-right.png x1 hinge inner right 20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x10 M4x8 T-nut.jpg x10 T-nut
Step 2/20 - Y-axis (30 min)
Y-idler
FR2-5-y-idler.png x1 y-idler M4x8 round-head.jpg x1 M4x8 T-nut.jpg x1 T-nut M3x25TCHC.jpg x1 M3x20 M3 washer.jpg x1 M3 washer 603zz.png x2 603zz bearing M3 nut.jpg x1 M3 nut
Y-motor
FR2-5-y-motor.png x1 y-motor M4x8 round-head.jpg x1 M4x8 T-nut.jpg x1 T-nut Nema14.jpg x1 nema 14 M3x8.jpg x2 M3x8 Timing pulley2.png x1 pulley FRM-screw threads x3.png x2 grub screw
Y-idler & motor
Rod-idler
FR2-5-rod-idler-front-left.png x4 rod-idler M4x8 round-head.jpg x4 M4x8 T-nut.jpg x4 T-nut
Step 3/20 - Plug + switch (45 min)
Cable 1
6,35mm-faston-ferule.jpg x1 4,8mm ferrule (+ insulation) 6,35mm-faston-ferule.jpg x1 6,35mm ferrule (+ insulation)
Cable 2
Cable 3
Cable 4
Cable 5
Plug-plate
FR2-5-plug-plate.png x1 plug-plate C14 CEI male-plug.jpg x1 plug Switch.jpg x1 switch M3x8.jpg x2 M3x8 M3 nut.jpg x2 M3 nut
Step 4/20 - Underplate (20 min)
Power supply fixing
FR2-5-underplate.png x1 underplate FRM-power-supply-150w.png x1 power supply M3x8.jpg x2 M3x8 M3 nut.jpg x2 M3 nut
Underplate fixing
Power supply wiring
Step 5/20 - Z-axis (1 hour)
Z-motors (1/2)
FR2-5-z-motor-left.png x1 z-motor left FR2-5-z-motor-right.png x1 z-motor right 20x20 300mm.jpg x2 300mm profile M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
Outer hinges
FR2-5-hinge-outer-left.png x1 hinge outer left FR2-5-hinge-outer-right.png x1 hinge outer right M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
Z-motors (2/2)
Nema14.jpg x2 nema 14 M3x8.jpg x4 M3x8
Z-sliders
FR2-5-z-slider-left.png x1 Z-slider left FR2-5-z-slider-right.png x1 Z-slider right M3x30 countersunk-head.jpg x1 M3x30 countersunk
Z-axis
M3 nut.jpg x2 M3 nut M3x20.jpg x2 M3x20
Step 6/20 - X-axis (1 hour)
M22-x-slider.png x1 x-carriage 20x20 200mm.jpg x1 200mm profile FRM-screw threads x3.png x6 grub screw
Nema14.jpg x1 nema 14 Timing pulley2.png x1 pulley FRM-screw threads x3.png x2 grub screw
M3x30 countersunk-head.jpg x4 M3x30 (countersunk) 603zz.png x2 603zz bearing FRM-belt.png x1 250mm belt
FR2-5-x-belt-end.png x2 x-belt end M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
Step 7/20 - Hotend (1 hour)
Heater block
FRM-heater-block.png x1 heater block FRM-nozzle.png x1 nozzle FRM-barrel.png x1 barrel
Heatsink
FRM-hotend-heatsink.png x1 heatsink FRM-pneumatic-fitting-MA1203M5.png x1 pneumatic fitting FRM-PTFE-tube.png x1 PTFE tube (2-4 mm) FRM-screw threads x3.png x1 grub screw
Thermistor
FRM-thermistor.png x1 thermistor Mini-fit fiche-femelle.jpg x2 female ferrule 2.54 mm 2-pin.png x1 2-pin casing
FRM-PTFE-tube.png x1 PTFE tube (2-3 mm)
Cartridge heater
FRM-cartridge-heater.png x1 cartridge heater FRM-screw threads x3.png x1 grub screw FRM-end-piece.png x2 cable terminal (1.5 mm)
Fan
Fan404010.png x1 fan FRM-ferule.png x2 ferrule (1mm) FRM-heatshrink-tubing.png x2 heatshrink sleeve
FR2-5-fan-railings.png x1 fan-grill M3x8.jpg x4 M3x16
Hotend holder
M22-hotend-holder.png x1 hotend holder M3x8.jpg x4 M3x8
M3x25TCHC.jpg x2 M3x25
Step 8/20 - XZ-axis (1 hour)
FR2-5-z-top-left.png x1 z-top left FR2-5-z-top-right.png x1 z-top right 20x20 200mm.jpg x1 200mm profile M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
FR2-5-handle.png x1 handle M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
Flexible-coupling-1.png x1 flexible coupling
M5-nylon-nut.png x2 nylon nut 230-235mm threaded-rod.jpg x1 threaded rod
Flexible-coupling-1.png x1 flexible coupling M5-nylon-nut.png x2 nylon nut 230-235mm threaded-rod.jpg x1 threaded rod
Step 9/20 - Bed (1 hour)
M3x30 countersunk-head.jpg x3 M3x30 countersunk M3 nut.jpg x3 M3 nut Bed springs RS751455.jpg x3 spring
FR2-5-y-carriage.png x1 y-carriage Linear-bearing-1.png x3 linear bearing Zipties.jpg x4 zip-tie
M3x8.jpg x2 M3x8
FR2-5-y-belt-clamp.png x1 belt clamp M3 nut.jpg x2 M3 nut
FR2-5-bed-adjuster.png x3 bed adjuster M3 nut.jpg x3 M3 nut
Smooth-rod-300mm.jpg x2 smooth rod
Zipties.jpg x5 zip-tie
Mini-fit fiche-femelle.jpg x2 female ferrule (2.54mm) 2-pin.png x1 2-pin casing
Step 10/20 - Endstops (30 min)
X-endstop
Micro-switch with-lever.jpg x1 endstop FRM-heatshrink-tubing.png x2 heatshrink sleeve FRM-ferule.png x2 ferrule
Y-endstop
Micro-switch with-lever.jpg x1 endstop FRM-heatshrink-tubing.png x2 heatshrink sleeve FRM-ferule.png x2 ferrule FR2-5-y-endstop-holder.png x1 y-endstop holder
Z-endstop
Step 11/20 - Blower (15 min)
Fan404010.png x1 blower FRM-ferule.png x2 ferrule FRM-heatshrink-tubing.png x2 heatshrink sleeve FRM-end-piece.png x2 cable terminal (1mm)
Step 12/20 - Extruder (45 min)
M3-0-extruder-corps.png x1 extruder 1 M3-0-extruder-levier.png x1 extrudeur 2 M3-0-extruder-capot1.png x1 extrudeur 3 M3x16.jpg x1 M3x10 603zz.png x1 603zz bearing
M3x25TCHC.jpg x1 M3x25
Bed springs RS751455.jpg x1 spring
M3x25TCHC.jpg x3 M3x25
Nema14.jpg x1 nema 17 FRM-insert.png x1 insert (+ grub screw)
Step 13/20 - Electronic board (15 min)
Potentiometers adjustment
Electronic board fixing
FR2-5-board-mount-minitronics.png x2 board mount M3x8.jpg x2 M3x8
M3x8.jpg x2 M3x8
Step 14/20 - Wiring (45 min)
E-motor
X-motor
Y-motor
Z-motors
Electronic board
Step 15/20 - Printing surface (30 min)
Kapton (option 1)
PrintBite (option 2)
Step 16/20 - Driver (15 min)
Step 17/20 - Firmware (15 min)
Step 18/20 - Software (35 min)
User interface
Testing
X testing
If the motor rotation is reversed go the the "readjustments" paragraph...
Y testing
Z testing
Hotend testing and adjustment
Extruder testing
Bed testing
Readjustments
Step 19/20 - Bed calibration (20 min)
Step 20/20 - Finishing touches (30 min)
Spiral sheath
Once your are sure that every part of the 3D-printer is adjusted you can bring the finishing touches:
Hinges-blocks
FR2-5-hinge-block-left.png x1 hinge block left FR2-5-hinge-block-right.png x1 hinge block right M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
Spool holder
FR2-5-spool-holder.png x1 spool-holder M4x8 round-head.jpg x1 M4x8 T-nut.jpg x1 T-nut
1st printing
Modelling
Netfabb Basic
Check the quality of your .stl file on Netfabb Basic: you might "repair" or re-arrange your .stl file on Netfabb
If the automatic repair doesn't wotk: use the red cross button to identify the origin of the problem and re-open your file under the CAD software extension to correct the problem manually (don't forget to re-export the model as a .stl file)
Slic3r
Define the printing parameters of your model in Slic3r
Pronterface
Drive your 3D-printer with Pronterface
Your FoldaRap is now ready. Have a lot of fun with your projects !
