LulzBot/Acrylic Electronics Mounting Plate
(Redirected from Acrylic Electronics Mounting Plate)
Release status: Working
Description | The Acrylic Mount Plate, for Prusa or Mendel design Reprap 3D printers, is capable of mounting RAMPS and/or Sanguinololu electronics.
License | GPLv3
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
About
The Acrylic Mount Plate, for Prusa or Mendel design Reprap 3D printers, is capable of mounting RAMPS and/or Sanguinololu electronics. The mount plate is made of 5.5mm thick clear acrylic that allows for better viewing than wooden mounting plates. Also, you have no worries of slicing your arm open on a sharp acrylic corner as the plate has rounded edges.
Specifications
- Capable of mounting RAMPS and/or Sanguinololu electronics
- 5.5mm thick clear acrylic (based on the material you use)
- Size: 28cm x 9cm x 5.5cm
- Rounded corners
Parts
- Acrylic electronics mount plate
- 4x Printed mount bracket (elc_mount_bracket.stl)
Other Vitamins
- 4x 6.35mm stand-off spacer
- 8x M3 35mm screws and nuts to mount the plate
- 8x M3 Nyloc nuts (or regular nuts with loctite)
- 8x M3 washers
- 4x M3 screws to mount the electronics (length depends on your electronics)
