XCbot
Revision as of 07:12, 15 January 2011 by Araspitfire (talk | contribs) (Description)
XCbot
Release status: unknown
documenting a generic tool/artpiece
[[1]]Blog
Another Extruded Aluminum Cartesian Bot.
This is 800 pixels wide, and on the left.
Structure:
Flexlink XC aluminum structural tslot extrusion.
Configuration:
Similar to Mendel.
Build Volume:
33cm High x 30cm Wide (X) x 23.5cm Deep (Y)
Materials:
Aluminum extrusion.
Note: After printing and using a Mendel for some time. I have decided that XCBot is not worth 'filling out', with respect to specific build information.
While it prints fine, and is very robust.. the cost was about 1000 euros, and there are core aspects of the design that I would not reccommend. Specifically the Z axis sliders.. were expensive and not as good as the bearing configuration on the X and Y. XCBot much louder in operation, due to the radiative nature of the materials.. and the NEMA 23 motors.
Additionally, it is my opinion that anyone who could fabricate the custom parts, would likely 'go their own way'... so the effort to 'finish' this description would be better spent on other things.
Files (Coming Soon!!!)
Your-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Your-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
Bill of Materials/Parts List
Downloads
Coming soon.
Photos and Drawings
Links
[2]Smugmug Photo Page (lots more images)
[3]Blog for this project.
Notes:
Try using sample mediawiki stuff from Example --Sebastien Bailard 23:14, 17 July 2010 (UTC)
This bot seems to be named after FlexLink's brand of extruded t-slot, series XC. [4]
