What Tooling Do You Have
Revision as of 16:25, 8 November 2010 by WikiSysop (talk | contribs) (Milling Machine)
This page has been flagged as containing duplicate material that Build a reprap also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
Community?
People are more important than tools. First check to see if you have a local RepRap User Group. Ideally, they may allow you to borrow a set of Mendel parts, as part of the Loaner Program. Or they'll be happy to sell you a set.
Already have a RepRap? Excellent!
If you have a RepRap, like Mendel, print a set of parts and build a RepRap. This is the ideal case. But if you are reading this, you don't have a RepRap yet.  :D
For Sale Forum
If you'd like to buy a set of parts, and you don't have a local RUG, try the For Sale Forums.
Table Saw
If you have a table saw, build a WolfStrap. You can also build a Wooden_Mendel but it is more complicated and a less elegant use of wood.
Milling Machine
If you have a milling machine, you could build a Metal_Mendel. but you're better off building a WolfStrap out of aluminum.
Or better, build a ORE-Bot. This may require metal-lathe operations, and Guy, ORE-Bot's designer, cheerfully says that it's a lot of work.
Drill Press
Build an Eiffel. And then add a Bill of Materials to the page.
No Drill Press?
Build an Eiffel, but use pre-drilled square steel tubing. And then add a Bill of Materials to the page.
Laser Cutter
If you have a Laser Cutter, build a LaserCut RepRap or a Pirated_CupCake. Many local shops which make and engrave trophies, desk ornaments, etc., have moved to Laser Cutters. Many local universities have laser cutters in their art/architecture/engineering/design departments.
Large CNC Router
If you have a large CNC Router, build an Isaac. (The Isaac is currently the best-documented FlatPack RepStrap design so far.)
Large Pile of Money
If you have a large pile of money, use a commercial 3D printer to print off a set of Mendel parts.
