Wade's Geared Extruder
Revision as of 16:38, 29 April 2010 by Casainho (talk | contribs) (Added link for pictures of other users that builded this extruder :-))
Release status: Stable
Geared Nema 17 Extruder
GPL
Characteristics/advantages of this extruder:
  • extrude/print at high speed;
  • good for use with a low torque Nema 17 motor;
  • no need to glue the PTFE barrel;
  • no need to use expensive metal gears;
  • no need to use expensive and complex tools - just one hand drill, a file and a M3 tap;
  • no need to make splines on motor shaft;
  • no need to do two precision flats on motor shaft;
See here pictures of it, from the users that builded it.
Mechanical Construction
Material
  • 3 X 608 bearings;
  • 1 X M8X50 bolt;
  • 1 X M8 nut;
  • 4 X M8 washers;
  • 1 X M8X20 piece of bar, threaded bar or a bolt;
  • 4 X M4X40 bolts;
  • 4 X M4 nuts;
  • 4 X M4 washers;
  • 4 X M3X10 bolts;
  • 2 X M3X35 bolts;
  • 2 X M3 nuts;
  • 8 X M3 washers;
How to build it
I used a hand drill and a file to cut the slot, then hobbed it with an M3 tap mounted in the drill, using bearings mounted in a vise to let the bolt spin - see the next videos:
So far so good!
Here's the test jig:
This extruder hit 16 kg - here's the results: M8 shoulder bolt - 7.0kg, adjusted tension, new springs - 11.0 kg,
Tightened springs, 3 trials:
15.5 kg, 16.5 kg, 15.25 kg
The final failure mode was the stepper running in reverse, as opposed to the filament slipping. That's quite promising.
3D CAD Files
Here's the design files for the latest version:
Finally, here's a spreadsheet to help calculate the proper feedrates: media:feedrates.ods | media:feedrates.xls
