VikOlliver
Revision as of 22:34, 27 December 2005 by VikOlliver (talk | contribs) (version migrated from twiki)
MkII Etxruder made from Adrian's FDM'd parts. The clamping effect is achieved by rubber rollers salvaged from an old printer paper feed roller, and the holed for the studding were drilled out for M4 'cos M3 studding was hard to get.
Some of the washers are very close, and in unimportant cases actually overlap. This can - and will- be solved with a few deft strokes of the file. The screws are not cap screws as they're scavenged from parts kindly donated by ECONZ Wireless.
The gearbox is also ECONZ salvage, and I've replaced its original 6V motor with a 12V motor from an Epson tally printer. The screw thread is not yet fitted, and so I've not built the mounting for the gearbox - it's just held there by the clamp.
-- Main.VikOlliver - 27 Nov 2005
First 3D Cartesian axis
No electrics other than the motor on the stage though. Should take standard circuitry, which I may try building on vero. But it does have steppers on all 3 axes:
  • First 3D Cartesian reprap axis:
Main.VikOlliver - 28 Dec 2005
