User:3D-ME
My name is Kyle Randall and I am a young RepRapper and tinkerer. I built a SAE Prusa i2 in 2013, and have been fixing the things I break, but if i get lucky, I'm printing with it.
Current RepRap Projects
I have several projects, and many ideas, but such little time and resources to do them!
SAE Prusa i2
I noticed that the SAE_Prusa_Mendel development page was for the first iteration of the Prusa Mendel, and I wanted the i2, so I did the conversion for the i2, and successfully made the first SAE i2 that I have heard of. Technically, I suppose it isn't fully SAE because I used GT2 belts and pulleys, but it sure helps reduce cost for those of us in the U.S., Myanmar, and Liberia. (Apparently Canada, too, I've heard) I plan on adding more info on this soon, and I can make a development page for this if others think that it would be helpful.
My All-Metal Hot End
I also made an all-metal hot end for my printer mainly to reduce the cost of my printer. It was a lot more learning that a complete newbie like myself expected, but after much work and effort, I produced a working all-metal hot end that cost me under $15 to make. I broke it last winter, and haven't gotten around to fixing it, as I bought a J-head, but I plan on rebuilding my hot end, (especially since I just broke my j-head,) and adding a bunch of documentation as well as instructions on building your own. I also plan on naming it. There will be more info on this and a development page once I get it re-built.
My Mini/Frankenstein All-Metal Hot End
I used a bunch of broken parts from my other all-metal hot end to build a ridiculously short hot end with a 1mm nozzle on it. It works with PLA, but has a slight leaking problem. It hasn't been tested with ABS, or prints that are longer than half an hour. The 1mm nozzle is quite interesting, and kinda fun to print with. I don't plan on developing this hot end much farther than I have, but I may write up some documentation for, but I may experiment with the 1mm nozzle on it some more.
A Solder-Extruding Hot End
This is an idea of an all-metal hot end that is specially designed to melt solder. I haven't done much with this design except research, drawing up a rough BOM and a diagram of how the prototype would work. This project is pretty much on the 'back burner' until I can get my other hot ends and projects done before developing this.
Arduino UNO Pololu Shield
I haven't made this yet, as I don't currently have the funds, but I do have BOM written up for the prototype. I think that this would be a valuable development for the community, as it seems that it would make a very simple and inexpensive electronics board -which would be great for beginners. If you are interested in this project, or want to develop it yourself, fell free to contact me here: Special:EmailUser/3D-ME.
3D-Printable End Stop Switch
Most current release: http://www.thingiverse.com/thing:389006
I saw this project as a challenge after breaking an end stop switch, so now I have developed a fully-working 3D printed end stop switch. More info at the link.
Links
Thingiverse: http://www.thingiverse.com/3D-ME/designs I have several designs posted here.
RepRap Forums: http://forums.reprap.org/profile.php?4,23860
