Useful Software Packages
Revision as of 20:01, 8 October 2011 by Weasel (talk | contribs) (HeeksCAD)
This is the place to put details of software packages that are useful for RepRap (like CAD programs), but that are not part of the RepRap project itself. Give a paragraph or so of explanation on each package and a link to its home page. Please also say what platforms it runs on, what licence it is distributed under, and whether it is free.
2D and 3D CAD software
Open-source software
OpenSCAD
OpenSCAD is a scripted modeller which produces CSG (Constructive Solid Geometry) and 2D outlines. It is free software and available for Linux/UNIX, MS Windows and Apples OS X. It supports DFX, STL and OFF file formats and is designed for the engineer not the artist. Can be used from the command line to generate bespoke STL objects. e.g. > openscad -m make -s gears_helical.stl -D teethNum=15 gears_helical.scad
OpenSCAD main page and download
Mailing list and archives
Manual
Endorsement
Art of Illusion
AoI is a graphics-oriented 3D modeller that's written entirely in Java. can be used to output STL files. or add Skeinforge to output GCode.
Although it is a 3D graphics design tool, it is also good for engineering design. It has a very easy and quick-to-learn user interface. AoI runs on Linux, Windows or Mac, and is freely available under the GPL.
AoI, for all its shortcomings, is probably the most used 3D modeling package in the RepRap community, primarily because of its very short learning curve. V2.7 experiences problems with booleans, and 2.6 is currently recommended - particularly with the CSG===Open-source software=== Evaluator plugin.
There is also a page on Reprap-specific plugins for AoI.
Art of Illusion
Blender
Blender was originally intended for the same applications as AoI. It has a very 'efficient' user interface, which includes a number of single-key keyboard commands. This is a very powerful and fast way of working, but can intimidate would-be users. (Don't be scared, blender is fun!) It may be arguably more powerful than AoI, and has a huge user community. Blender is scriptable in Python, runs on Linux, Windows or Mac, and is freely available under the GPL.
Blender
Also See:
BlenderCAD
BlenderCAD is a pre-alpha attempt to build CAD functionality into Blender.
BRL-CAD
BRL-CAD is a cross-platform open source solid modeling system that includes interactive geometry editing, high-performance ray-tracing for rendering and geometric analysis, image and signal-processing tools, a system performance analysis benchmark suite, libraries for robust geometric representation, with more than 20 years of active development. The BRL-CAD runs on BSD, Irix, Linux, Mac OS X, Solaris, and Windows. BRL-CAD became an open source project in 2004, with portions licensed under the LGPL and BSD licenses.
BRL-CAD
FreeCAD
FreeCAD is still under development, but it is intended to be a full 3D mechanical engineering CAD package. FreeCAD is based on OpenCasCade, QT and Python, runs on Linux and Windows, and is freely available under the GPL and LGPL.
FreeCAD
HeeksCAD
HeeksCAD, like FreeCAD, is based on OpenCasCade, and has similar modeling functionality, for solids slightly more, less for meshes, with neutral IGES, STEP and STL file format exchange. It's much less dependent on parametric editing than FreeCAD and the GUI is more integrated, not modular. Windows and various Linux builds. Distributed under BSD license.
HeeksCAD
QCAD
QCAD is an application for computer aided drafting in two dimensions (2D). With QCAD you can create technical drawings such as plans for buildings, interiors, mechanical parts or schemas and diagrams. QCAD works on Windows, Mac OS X and many Linux and Unix Systems. The source code of the free QCAD community edition is released under the GPL.
QCAD
Inkscape
Inkscape is an Open Source vector graphics editor, with capabilities similar to Illustrator, CorelDraw, or Xara X. It uses the W3C standard Scalable Vector Graphics (SVG) file format. Inkscape is released under GPL Version 2.
Inkscape
PythonOCC
A python wrapper for the OpenCascade and Salome (salome-geometry and salome-mesh) libraries. Supports constructive solid geometry, data exchange, meshing, GUI development (wxPython, PyQt, python-xlib), parametric modeling. FEM solver integration with (Code Aster) is underway. (Not a GUI based CAD program, but aims to be a scripting framework for rapid development of custom CAE solutions.)
PythonOCC
Wings3D
A fairly simple 3D modeller. Designs can be exported as STL and STL files can be imported. Wings3d can be extended using available plugins, and you can write your own plugins in Erlang.
Wings3D
K3D
Another simple 3D modeller with no STL support.
K3D
Unknown licence
AutoQ3D
AutoQ3D Animation is an easy 3D CAD with animation capabilities. It is suitable for anyone interested in learning 3D CAD and Animation before using more sophisticated packages.
AutoQ3D
Archimedes
Brasilian 3D package. Apparently became orphanware in 2007.
Archimedes
Closed source
Autodesk Inventor (Student Version)
Students can download the professional version of Autodesk Inventor 2010, 2011 or 2012 after registration on the Autodesk website (link below). It is a powerful tool for creating 3D CAD models. It can import and export the industrial standard CAD files like STEP or IGES and export STL files.
Autodesk
CoCreate
CoCreate Modeling Personal Edition is free for non-professional use. It is limited to 60 parts in one design and can only save designs in its own proprietary format, but it can export STL and VRML and import STEP and IGES. It is Windows only and needs an internet connection every three days. Apparently, very easy to use. {content abstracted from Hydraraptor}
CoCreate
Google Sketchup
Google Sketchup is primarily intended for designing architectural models, but it can be used for general 3D design as well.
Google Sketchup
For details of plugins that will output STL files from Sketchup: see here (cerebralmeltdown.com) and here (capolight.wordpress.com) and here a FREE one (guitar-list.com)
iTracer
iTracer is a 3D modeling and rendering application for the iPhone. There are instructions for creating models for 3D printing using it on Instructables here. It costs $2.
iTracer
Rhino
Rhino is an easy 3D CAD with strong modeling capabilities. It is the most used software in entire micro-verticals such as architecture and jewelry.
[1]
Software for dealing with STL files
MeshLab
An open source, portable, and extensible system for the processing and editing of unstructured 3D triangular meshes. It also has an as yet unexploited object slicing routine which is extremely quick.
MeshLab
netfabb Studio
A tool for repairing and manipulations of STL files.
netfabb Studio is free, but not open source. It is Windows only. An alpha of a Linux version that prints on a RepMan was announced.
netfabb Studio is software tailored for additive fabrication, rapid prototyping and 3D printing. It includes the ability of viewing, editing, repairing and analyzing stl-files or slice-based files in various formats.
netfabb Studio
Skeinforge
Converts STL files to Gcodes. Is included with ReplicatorG. Horribly ugly user interface. It looks like someone used a shotgun loaded with buttons.
CAD software for electronics
gEDA/gaf
A full GPL'd suite and toolkit of Electronic Design Automation tools. These tools are used for electrical circuit design, schematic capture, simulation, prototyping, and production.
Compiles / runs on Linux and Mac Os X. Binaries available for Debian, SUSE, and Mac.
gEDA Wikipedia
KiCad
An open source (GPL) software for the creation of electronic schematic diagrams and printed circuit board artwork. Users are making complex boards with it, as boards of 4 layers or more, with ARM microcontrollers running at 450MHz.
It runs on Linux, Windows or Mac. It is available on Linux Ubuntu repositories ("app store") meaning that it can be installed with one mouse click.
KiCAD
Gerbv
An open-source (ODV) program for displaying Gerber files. Useful for checking.
Gerbv
Stripboard Designer 1.0
Open source (BSD) app written in freeware Visual Basic 2008 Express for Wintel machines
Stripes
Open source (GPL) version of Stripboard Designer written by Julian Skidmore in Java
Stripes
Closed-source
Eagle
Proprietary circuit-diagram and PCB design system with a slightly reduced-capabilities freeware version. It includes an autorouter for PCB creation. This is the package that has been used to design the majority of the RepRap electronics. It is also used to design the open-source Arduino microcontroller, derivatives of which are used in RepRap. It runs on Linux, Windows or Mac.
Eagle
Further reading
_Manual Manual]
Endorsement
