Toolcontroller
Revision as of 12:31, 31 December 2013 by Jos (talk | contribs) (To control a tool that is not natively used on a machine)
Toolcontrollers can be used for 2 purposes.
  • To control a tool that is not natively used on a machine (Toolcontroller is located near mainboard)
  • To eliminate EMC (toolcontroller located on the tool)
This can be used when you have a CNC mill, and you want to add a 3D print extruder and heatbed to it
Toolcontrollers located at the tool to eliminate EMC
ToolController EMC
Toolcontroller
Creative Commons Atribute-Non Comercial-Share Alike by MaukCC
see files
With these ToolControllers there is no need to transport high amp, high frequency pulses to your tools.
You just add power and low level signal wires.
By doing so we eliminate the EMC generated over long wires created by stepper motor drivers and other high power PWM signals.
Allowing you to comply with UL and EC standards.
Extruder controller
Extruder controller functions:
  • steppermotor driver
  • heater driver
  • fan driver
  • thermocouple support
  • lights (to see what your tool is doing)
  • control LED`s for heater on, heater temp, fan on
  • extruder body temperature control
This Controller is mounted direct to a NEMA17 motor.
Fan controller
  • fan driver
  • control LED`s for fan on
Engraver controller
  • Engraver driver
  • control LED`s for Engraver on
