Step 1 - Components
You will need one drive for each colour/material that your Mendel will print, up to a maximum of three. This section describes the parts for one drive.
Item
Quantity
Large internal gear (printed)
1
Small push-fit gear (printed)
1
Main block (printed)
1
Tongue (printed)
1
PCB clips (printed)
2
Slotted custom PCB clip (printed)
1
Flat motor spacer (printed)
1
M3 nuts
5
M3 nyloc nuts
3
30mm M3 caps
2
35mm M3 caps
1
25mm M3 caps
1
25mm M3 screw (threaded to the top)
1
20mm M3 caps
3
12mm M3 caps
1
M3 spring washer
1
M3 washers
13
3mm 623 bearings 10mm OD x 4mm thick
3
8mm M3 hobbed drive
1
Short NEMA 17 motor
1
Step 2 - Assembly
