TeensyluV1
Revision as of 14:04, 9 November 2015 by StephS (talk | contribs) (Created page with "{{Languages}} {{Development:Stub}} {{Development |name = TeensyluV1 |image = TeensyluV1.jpg |status = Experimental |description = Version 1.3a |author = StephS |reprap = Teens...")
TeensyluV1
Release status: Experimental
Version 1.3a
unknown
Eagle
Introduction
This is a project that is based on Teensylu with heavy influence from Printrboard. The board has been completely redesigned with higher rated connectors, an onboard voltage regulator, uSD card slot, a mini blade fuse, and high power SMT mosfets. Power supply now uses either a 6 pin PCIe power connector, or a 4 pin screw terminal. USB is connected through a micro usb connector.
For 12v compatibility, the board MUST be made with 2oz copper layers. 24v can be done with 1oz layers. It is highly recommended to use a 24v supply as it is much safer with lower current. They are 2 versions of the board, 2 layer and 4 layer. Currently only the 2 layer version is supported.
Features
  • Small design - board is 4" x 3"
  • Teensylu clone, Atmel's AT90USB1286 - AT90USB1287 drop-in compatible for 20mhz support
  • Up to 4 Pololu stepper driver boards (or Pololu compatible) on-board (X,Y,Z,Extruder) (without voltage regulator)
  • Supports multiple power configurations (Carried from Sanguinololu)
-- Main power by either screw terminal or ATX PCIe 6 pin connector 12-28V
-- Logic supplied by onboard 5v switching regulator
-- Logic can also be supplied by USB bus (do not supply main supply at the same time, may damage board or your computer!)
-- on-board USB connectivity
  • 2 thermistor connectors with circuitry
  • 2 SMT N-MOSFETs for extruder/bed heaters
  • 1 Fused N-MOSFET for low power fan or motor
  • Selectable 12v/5v endstop voltage
-- 4 endstops including 4th stop called E-Stop to be used as an emergency stop, or extruder stop (to be added in firmware).
-- The Z endstop has been changed to a 4 pin design. Pin 1 now supplies 12-28v for inductive probe sensors. The input is 12v tolerant (has not been tested with higher voltages).
  • Edge connectors enabling right-angle connections
  • 14 Extra pins available for expansion and development.
-- TODO - List expansion capabilities
  • SMT Components sized at 0603 for easier soldering.
Software
Compatible Firmwares
TODO: Update list of firmware to include TeensyluV1
Pinout
The pin mapping is supplied in the Github repository.
Board Images
Schematics
Board and schematic on Github: [[1]]
Bill of Materials
TeensyluV1 Bill of Materials 1.3a version
Part Value Device MANUFACTURER MANUFACTURER_PART_NUMBER
C1 4.7uF CAPACITOR_1206 Yaiyo Yuden UMK316AB7475KL-T
C2 0.1uF CAPACITOR_0603 Murata GRM188R71C104KA01D
C3 0.1uF CAPACITOR_0603 Samsung CL10B104KB8NNNC
C4 0.1uF CAPACITOR_0603 Murata GRM188R71C104KA01D
C5 0.1uF CAPACITOR_0603 Murata GRM188R71C104KA01D
C6 0.1uF CAPACITOR_0603 Murata GRM188R71C104KA01D
C7 10uF CAPACITOR_0805 Murata GRM21BR71A106KE51L
C8 1uF CAPACITOR_0603 Samsung CL10A105MO8NNNC
C9 10uF CAPACITOR_0805 Murata GRM21BR71A106KE51L
C10 10uF CAPACITOR_0603 Murata GRM188R61C106MA73D
C11 100uF CPOL-USD Panasonic EEE-FTH101XAP
C12 10pF CAPACITOR_0603 Samsung CL10C100JB8NCNC
C13 10pF CAPACITOR_0603 Samsung CL10C100JB8NCNC
C14 100uF CPOL-USD Panasonic EEE-FTH101XAP
C15 10uF CAPACITOR_0603 Murata GRM188R61C106MA73D
C16 10uF CAPACITOR_0603 Murata GRM188R61C106MA73D
C17 100uF CPOL-USD Panasonic EEE-FTH101XAP
C18 100uF CPOL-USD Panasonic EEE-FTH101XAP
C19 100uF CPOL-USD Panasonic EEE-FTH101XAP
C20 100uF CPOL-USD Panasonic EEE-FTH101XAP
D1 SCH-DIODESOD123F SCH-DIODESOD123F NXP Semiconductors "PMEG4010CEH,115"
D2 SCH-DIODESOD123F SCH-DIODESOD123F NXP Semiconductors "PMEG4010CEH,115"
F1 MINISMDC050F1812 MINISMDC050F1812 TE Connectivity MINISMDC050F-2
F2 MINI-FUSEMINI-FUSE MINI-FUSEMINI-FUSE Keystone 3568
J1 22ga WIRE_JUMPER-0.1 N/A N/A
J2 22ga WIRE_JUMPER-0.1 N/A N/A
J3 22ga WIRE_JUMPER-0.1 N/A N/A
J4 22ga WIRE_JUMPER-0.1 N/A N/A
J5 22ga WIRE_JUMPER-0.1 N/A N/A
J6 22ga WIRE_JUMPER-0.1 N/A N/A
J7 22ga WIRE_JUMPER-0.1 N/A N/A
J8 M02POLAR M02POLAR Molex 22272021
J9 M02POLAR M02POLAR Molex 22272021
J10 MICROSD MICROSD Amphenol 114-00841-68
J11 USB-MICRO-PTH USB-MICRO-PTH FCI 10118194-0001LF
J12 M02POLAR M02POLAR Molex 22272021
J13 4P-TERM-BLOCK284391-4 4P-TERM-BLOCK284391-4 TE Connectivity 284391-4
J14 HOTEND-1 4P-TERM-BLOCK284391-4 TE Connectivity 284391-4
J15 39-29-3066 39-29-3066 Molex 39293066
J16 2x7 JP7Q Harwin M20-9980746
J17 HOTBED 4P-TERM-BLOCK284391-4 TE Connectivity 284391-4
J18 M02POLAR M02POLAR Molex 22272021
J19 M02POLAR M02POLAR Molex 22272021
JP1 ISP PROGHEADER
JP5 BOOT JUMPER-2PTH Harwin M20-9990246
JP6 JUMPER-3PTH JUMPER-3PTH
JP7 Z-STOP M04POLAR Molex 22272041
JP8 M03POLAR M03POLAR Molex 22272031
JP9 M03POLAR M03POLAR Molex 22272031
JP10 M03POLAR M03POLAR Molex 22272031
JP11 MOT-X M04POLAR Molex 22272041
JP12 MOT-Y M04POLAR Molex 22272041
JP13 MOT-E1 M04POLAR Molex 22272041
JP14 MOT-Z M04POLAR Molex 22272041
L1 68uH INDUCTORSRN6045 Bourns SRN6045-680M
LED1 POWER LEDCHIPLED_0805 Kingbright APT2012SGC
P1 POLOLU-X POLOLU-ALLEGRO
P2 POLOLU-Y POLOLU-ALLEGRO
P3 POLOLU-Z POLOLU-ALLEGRO
P4 POLOLU-E1 POLOLU-ALLEGRO
Q1 PMV45EN MOSFET-NCH_SOT-23 International Rectifier IRLML2060TRPBF
Q2 PSMN1R8-40YLC PSMN1R8-40YLCPOWERPACK-S08 NXP Semiconductors "PSMN1R8-40YLC,115"
Q3 MMUN2211LT3G TRANSISTOR_NPN_BIASSOT23C ON Semiconductor MMUN2211LT3G
Q4 PSMN1R8-40YLC PSMN1R8-40YLCPOWERPACK-S08 NXP Semiconductors "PSMN1R8-40YLC,115"
R1 1K RESISTOR_0603
R2 10k RESISTOR_0603
R3 100 RESISTOR_0603
R4 36k RESISTOR_0603
R5 6.49k RESISTOR_0603
R6 22 RESISTOR_0603
R7 22 RESISTOR_0603
R8 10k RESISTOR_0603
R9 100 RESISTOR_0603
R10 100k RESISTOR_0603
R11 100k RESISTOR_0603
R12 10k RESISTOR_0603
R13 100 RESISTOR_0603
R14 4.7k RESISTOR_0603
R15 4.7k RESISTOR_0603
R16 100k RESISTOR_0603
R17 100k RESISTOR_0603
R18 100k RESISTOR_0603
R19 100k RESISTOR_0603
S1 RESET TAC_SWITCHSMD Bourns 7914J-1-000E
U1 LMR16006X LMR16006X Texas Instruments LMR16006XDDCT
U2 DRTR5V0U2SR DRTR5V0U2SR Diodes Incorporated DTR5V0U2SR
U3 AP7313SOT23C AP7313SOT23C Diodes Incorporated AP7313-33SAG-7
U4 TXB0104TSSOP14 TXB0104TSSOP14 Texas Instruments TXB0104PWR
U5 AT90USB1286 AT90USB Atmel AT90USB1286
X1 16MHZ XTAL NDK NX5032GA-16.000000MHZ-LN-CD-1
