Talk:Builders/Software and firmware
< Talk:Builders
Revision as of 09:02, 5 March 2013 by Nexgenamcmms (talk | contribs) (Add-On Modules With Facility Maintenance Management)
The work which was done manually and consumed so much time is now made simple and no time constraint which Facility maintenance software. The general modules used in such software solutions are work order management, maintenance management, inventory management, contract management, asset management, material management, space management, fleet management, project management, utility management and preventive maintenance management. Facility Maintenance Management customizes the modules as per the requirement for each organization to stay different from each other. With the flexibility provided by customization of these modules, organization can grow their needs, requirements and demands simultaneously. These software solutions are developed and designed in order to provide with ease-to-use, robust enough to fulfil the needs and requirements in certain demanding professions.
Documentation Is Made Easy
Desktop solutions, web-based solutions and compatibility with existing information system are also provided. With Facility maintenance Management, documentation is made easy, and thus integration with documentation systems is ensured. As the involvement of managerial team is important, some strategic decisions with regards to Facility Maintenance Software, integrations with the organization’s management information are also sought by Facility maintenance software.
