TITAN
Revision as of 20:33, 15 March 2016 by DavidCary (talk | contribs) (test)
TITAN
Release status: experimental
Tiny portable 3D printer
Creative Commons
Design
The TITAN is a 190x190x190mm machine designed for portability. It's the printer you take with you when you want to print something at a friends place. It has a build envelope of 80x80x70mm.
Specifications
  • Printed Parts: ???
  • Non-Printed Parts: ???
  • Printing Size: 80mm x 80mm x 70mm (3.1"x3.1"x2.75")
  • Material Cost: ???
  • Costs: ??? (assembled)
  • Precision: ??? (position), ??? (printing)
  • Speed: ??? (position), ??? (printing)
Status
It's currently under development, and the first prototype is being build. It's a huge challenge to get all parts as small as possible.
Current problems:
  • The Z stage cannot have a motor under it. Currently attempting an winching system.
  • The HotEnd is an Ultimaker hotend (due to having a spare). But this hotend is quite large for the machine.
  • Electronics are not yet fit into the design. I might design new electronics based on an LPCxpresso and 4 Pololu drivers.
Ideas
People have many suggestions for this machine. Many of those can be tried later on.
  • Use a car-jack like system for the Z stage
  • Use wire instead of timing belts
  • Investigate if a CoreXY frame could save space
  • Investigate if you could remove 2 of the X/Y frame axes and just have the moving axes slide in a slot (requires a very rigid slider block)
  • Design a custom, smaller hotend
