Smooth rod
Revision as of 20:27, 29 May 2013 by Virtlink (talk | contribs) (moved Smooth-rod to Smooth rod: No need for a dash in the name)
Smooth rod
Vitamin
Smooth metal rod, used as axis.
Wikipedia none
A smooth rod is a metal rod usually used on the axis for components such as the X-carriage or print bed to slide on. The most commonly used type of smooth rod is stainless steel M8 (8 mm diameter). Stainless steel is a pretty hard steel, and doesn't rust, making them ideal to slide bearings on.
Not all rods are created equal, and lower quality rods might be too small or too big by a fraction of a millimeter, which will cause problems with the bearings. Ensure that your rods hace the correct diameter, or when buying, ensure that they are M8 with about H6 tolerance.
Smoothing the smooth rod
If the finish of your smooth rods is too rough, you can smooth it up by carefully sanding the surface with an 800 grit wet & dry abrasive paper, then a 1200 grit paper. Then put the final polish on the rod using metal polishing paste (the same stuff as what people use to polish their car wheels). In about two hours you'll have all your rods polished.
Vendors
Vendor (shipping location) Product Diameter Length Tolerance Material Additional notes
Ridings et Dafrodis (FR) Ronds Pleins 3-30 mm 1000 mm   Inox 316L
HPC Europe (FR/IT) Shaft for linear guidance 5-80 mm 1000 mm H6 Cf53 hardened
Motedis (FR) Arbre acier 6 mm 5-200 mm   Cf53 hardened
Technobots (UK) Silver Steel 2-30 mm 333 mm
ULM Technologie (FR) Tube acier inox 8-60 mm 1000 mm   Inox 304 It is possible to indicate a cutting length in the comment area of the cart just before finalizing the order.
VXB (US) Rod Linear Motion] 8 mm 762 mm
