Skeinforge
Example Development
Release status: unknown
Description | documenting a generic tool/artpiece
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Skeinforge is described [here].
It can be downloaded [here].
Skeinforge is written in the programming language Python. To run Skeinforge you will need Python. Python can be obtained [here.]. The official website for Python is [here].
Note
Since skeinforge is a big part of the RepRap toolchain for a lot of people we may want to maintain a local mirror of it, along with incorporating all the tutorials. --Sebastien Bailard 18:57, 11 January 2010 (UTC)
Troubleshooting Tips
- Extruder not moving
- You need the dimensions module loaded to generate E codes, which drive the extruder.
- Heater not heating when raft module disabled
- The raft module also controls preheating. To stop printing rafts, simply set the layer-counts in the raft module to 0, rather than disabling it.
- Extruder running backwards at start of print
- Technically this is not a problem with Skeinforge, but you can make a simple change in Skeinforge to work around it. The issue is caused by manual extrusion (through RepRapHost, RepSnapper) prior to a print changing the E value calculated by your firmware.
- To fix, in your start.gcode file add the command 'G92 E0' which resets the E count to 0.
- Notes
- The start.gcode should be in the directory ...\skeinforge_application\alterations where "..." is the directory skeinforge is installed in.
- This file needs to be referenced in the "Name of Start File:" entry, under the "Name of Alteration Files" section of the "Preface" tab.
- Volume-based extrusion
- Skeinforge 040 made some drastic changes to the dimension module (for the better). Check here for help setting it up.
