RustyHuxley
Revision as of 22:42, 9 December 2010 by RustySpoon (talk | contribs)
RustyHuxley
Release status: experimental
unknown
This is a redesigned Huxley inspired by the Prusa simplified Mendel.
It uses the PLA Bushings like these. I modified the scad script to use 6mm rods. (basically just put in 6mm for rod size and 12mm for width)
I have also redesigned the X and Y motor brackets to be able to use nema 14 or 17 motors. The Z now takes 2 nema 14 motors.
I designed it around 1/4" threaded rods and #6-32 bolts. It should work with 6mm rods and M6 bolts, but I'm not sure.
This should work with the same extruders as the regular Huxley. I believe.
