RustyHuxley
Revision as of 22:32, 9 December 2010 by RustySpoon (talk | contribs)
RustyHuxley
Release status: experimental
Description | |
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This is a redesigned Huxley inspired by the url = Prusa simplified Mendel.
It uses the PLA Bushings like
thingiverse.com/thing:4434
I modified the scad script to use 6mm rods.
(basically just put in 6mm for rod size and 12mm for width)
I have also redesigned the X and Y motor brackets to be able to use nema 14 or 17 motors. The Z now takes 2 nema 14 motors.
I designed it around 1/4" threaded rods and #6-32 bolts. It should work with 6mm rods and M6 bolts, but I'm not sure.
This should work with the same extruder as the regular Huxley. I believe.
