Rroofl M8 Parts List
Revision as of 21:16, 7 May 2013 by Vikolliver (talk | contribs)
When making a Rroofl on a 3D printer, the usual approach is to use an M8 threaded rod frame. The printed parts are shown and labelled in the following image. Note that when giving someone a kit, it is advisable to provide some spare parts that are known to wear or break when incorrectly fitted. These include small drive gears, belt gears and PLA linear bearings. As a courtesy, Diamond Age also supply a little packet of "Morph" which can be softened in hot water and used to repair or fill out broken or distorted parts, should they become mangled by careless couriers, enthusiastic pets etc.
Printed components found in a Rroofl with an M8 frame
STL Files can be found here:
http://www.thingiverse.com/thing:85198
Cutting list for rods TBA
Fasteners TBA
Wooden parts cut from 6mm MDF TBA
Use johnnyr's excellent RAMPS electronics if you've nothing else in mind.
A heated bed is not necessary if you are only printing PLA, but one can be permanently or temporarily attached to the build bed.
Back to Rroofl.
