Rroofl M8 Parts List
When making a Rroofl on a 3D printer, the usual approach is to use an M8 threaded rod frame. The printed parts are shown and labelled in the following image. Note that when giving someone a kit, it is advisable to provide some spare parts that are known to wear or break when incorrectly fitted. These include small drive gears, belt gears and PLA linear bearings. As a courtesy, Diamond Age also supply a little packet of "Morph" which can be softened in hot water and used to repair or fill out broken or distorted parts, should they become mangled by careless couriers, enthusiastic pets etc.
STL Files can be found here:
http://www.thingiverse.com/thing:85198
Cutting list for rods TBA
Fasteners TBA
Use [user:johnnyr]'s excellent RAMPS_1.4 RAMPS electronics if you've nothing else in mind. A heated bed is not necessary if you are only printing PLA.
Back to Rroofl.
