Rostock-Montpellier
Revision as of 17:02, 28 July 2013 by Njprossi (talk | contribs)
Rostock-Montpellier
Release status: experimental
Rostock-Montpellier is a portable delta robot 3D printer.
The Rostock-Montpellier is a delta 3D printer based on the Rostock mini. It is focused to print as fast as possible and sustain it for a couple of hour.
Design goals
Target setting to print a bunch of parts quickly.
  • Acceleration : 10G
  • Speed, Travel : over 1000mm/s
  • Volume : Ø170x170
Actual settings
  • Accleration, XY : 4G (39224mm/s²)
  • Accleration, Z  : 1G (9806mm/²)
  • Speed, travel : 800 mm/s
Performed settings
Setting used with the latest prototype during "Les 24h de l'imprimante 3D" show at Montpellier in June.
  • Accleration, XY : 2G (19613mm/s²)
  • Speed, travel : 700 mm/s
  • Speed, infill : 160mm/s
  • Speed, perimeter : 120mm/s
  • Speed, external perimeter : 70mm/s
  • Layer : 120µm
  • Volume : Ø170x127mm
Prototype design
To accelerate the Rostock and get high speed without replacing motors by expensive one, according the Newton's 2nd Law there is 2 things to do :
  • The parts in movement have to be lighten. If the mass is divided by two, the acceleration can be multiplied by 2.
  • The frictions have to be reduced, less force to move, more accleration.
The platform and the carriage has been redesigned in a way that an existing Rostock can be updated with the Rostock-Montpellier parts.
Retour d’expérience
