Replikeo Prusa i3
Revision as of 05:06, 12 March 2016 by Replikeo (talk | contribs) (Required tools)
Replikeo Prusa i3
Prusa i3 based on eMotionTech Prusa i3 Rework and RepRap Pro Ormerod 2
Required tools
Tools allen keys.jpg Tools electrical screwdriver.jpg Tools screwdriver.jpg Tools adjustable wrench.jpg Tools tweezers.jpg
Allen keys (1.5mm, 2mm, 2.5mm, 4mm) Electrical screwdriver (Slot) Screwdriver (Phillips) Adjustable wrench (x2) or M5 wrench Tweezers
Tools ruler.jpg Tools needle nosed pliers.jpg Tools scissors.jpg Tools drill bit.jpg Tools drill.jpg
Ruler Needle-nosed pliers Scissors 2mm, 3mm, 4mm drill bit Drill or hand drill
Tools pencil sharpener.jpg Tools multimeter.jpg Tools lighter.jpg Tools file.jpg Tools utility knife.jpg
Pencil sharpener Multimeter Lighter File Utility knife
Y-axis Assembly
Heated bed mount
  • Heated bed mount
  • Y-belt-holder
  • 3x Linear bearing LM8UU
  • 2x M3x14 mm screw
  • 2x Ø3 mm washer
  • 2x M3 nut
  • 3x zip-ties
Replikeo prusa i3 heatbed mount 1.jpg Bottom
Replikeo prusa i3 heatbed mount 2.jpg Top
Transverse parts
  • 4x Y Corner
  • Y Idler
  • Y Motor
  • 1x Ball bearing 608
  • 4x Threaded rod M10x210 mm
  • 22x M10 nut
  • 22x Ø10 mm washer
  • 1x M8x30 mm screw
  • 1x M8 nut
  • 2x Ø8 mm wahser
  • 1x M4x20 mm screw
  • 1x M4 nut
Assembly with the longitudinal parts
  • Heated bed mount assembly
  • Transverse parts
  • 2x Smooth rod Ø8x350 mm
  • 2x Threaded rod M10x380 mm
  • 12x M10 nut
  • 12x Ø10 mm washer
X axis assembly
X End Idler and X End Motor assembly
  • X End Idler
  • X End Motor
  • 1x 624 ball bearing
  • 4x LM8UU linear bearing
  • 1x Endstop
  • 2x M5 nut
  • 1x M4x20 mm screw
  • 1x M4 nut
  • 2x M3x14 mm screw
  • 2x M3 nut
X Carriage
  • X Carriage
  • Zip-ties
X-Axis assembly
  • a
Connecting X axis and Z axis
  • Single frame
  • X-axis assembly
  • Z Axis Top Left
  • Z Axis Top Right
  • Z Bottom Left
  • Z Bottom Right
  • 2x Smooth rod Ø8x320 mm
  • 10x M3x14 mm screw
  • 10x M3 nut
  • 10x Ø3 mm washer
Motor assembly
Z-axis
thumb
  • Endstop Z Holder
  • 2x Coupling 5x5
  • 2x NEMA 17 motor
  • 1x Endstop
  • 2x Threaded rod M5x300 mm
  • 8x M3x14 mm screw
  • 2x M3 nut
  • 8x Ø3 mm washer
Z Endstop
(Skip this part if you have the proximity sensor version)
thumb
  • Endstop Z Holder
  • 1x Endstop
  • 2x M3x14 mm screw
  • 2x M3 nut
  • 2x Ø3 mm washer
thumb
thumb
Y-axis
thumb
  • 1x NEMA 17 motor
  • 1x Endstop
  • 1x GT2 pulley
  • 5x M3x14 mm screw
  • 2x M3 grub screw
  • 2x M3 nut
  • 5x Ø3 mm washer
thumb
  • b
X-axis
thumb
  • 1x NEMA 17 motor
  • 1x GT2 pulley
  • 3x M3x14 mm screw
  • 2x M3 grub screw
  • 3x Ø3 mm washer
thumb
  • b
Mechanical frame assembly
thumb
  • Y-axis assembly
  • Single frame assembly
thumb
  • b
X and Y-axis motions
Belts
Heated bed assembly
Heated bed assembly
Extruder drive assembly
thumb
  • 623 bearing (10mm diameter)
  • M3 washer
  • 3x M3x12mm countersunk socket screw
thumb
thumb
  • M3 washer
thumb
  • Tighten
thumb
  • M3x25mm hex head screw
  • 2x M3 washer
  • MR93ZZ bearing (9mm diameter)
  • Hobbed insert
  • M3 nyloc nut
thumb
thumb
thumb
  • Small gear
  • Large gear
thumb
Extruder assembly
Complementary documentation :
https://reprappro.com/documentation/ormerod-2/hot-end-assembly-quick-set/
Nozzle assembly
  • PTFE bowden tube
  • Quick-set Tapered brass M4 nut
  • Quick-set heater block
  • Quick-set nozzle
  • Quick-set cooling block
  • Bowden end
Hotend assembly
  • Assembled nozzle and bowden tubing
  • Heatsink
  • Fan spacer
  • Fan with heater cartridge
  • Thermistor with tubing
  • Cap head screws
Extruder body assembly
  • Heatsink
  • Fan spacer
  • Cap head screws
Tongue and bowden
Cabling
Motors cabling
Endstops cabling
Auto bed leveling
Proximity Sensor
400px
Electronics and wiring
Mounting electronics
thumb
  • RAMPS
  • Arduino Mega 2650
  • 4x stepsticks
  • 3x Arduino washer
  • 3x M3x24 mm screw
  • 3x M3 nut
  • 3x Ø3 mm washer
thumb
Wiring
thumb
  • Yellow : Jumpers
  • Green : Proximity sensor
thumb
  • RAMPS wiring
thumb
  • 1 [V+] : RAMPS [+] (red)
  • 2 [V+] : RAMPS [+] (red)
  • 3 [V+] : Fan (red) ; proximity sensor (red)
  • 4 [COM, V-] : RAMPS [-] (black)
  • 5 [COM, V-] : RAMPS [-] (black)
  • 6 [COM, V-] : Fan (black)
  • 7 [GND] : Mains Powered Ground
  • 8 [N] : Mains Powered
  • 9 [L] : Mains Powered
Software
thumb
  • Download Arduino IDE (you may need to use a former version of the Arduino IDE if you have compilation errors with the last version of Marlin, i.e. 1.6.1)
  • Download Marlin firmware
  • Download Marlin configuration file from Replikeo's Github Github, rename the selected file "Configuration.h" and replace the default Marlin configuration file by this one.
thumb
  • Open marlin
  • Change file Configuration.h by Replikeo's Configuration.h file
thumb
  • Select Arduino Mega 2560 in Tools > Board Type
  • Connect to your Arduino through USB, select it in Tools > Serial Port
  • Compile Marlin
thumb
  • Flash Marlin firmware on your Arduino
thumb
thumb
thumb
  • Open Slic3r and and load replikeo_dual_config.ini : File > Load config
  • Select the new configuration Dual Prusa Ormerod for the different categories within slic3r : Print settings, Filament and Printer
thumb
  • Download calibration files from thingiverse.com
  • There is two .stl files that make up the object
thumb
  • Load a first .stl file into slic3r
thumb
  • Select your object in slic3r and click on Settings
  • Load the second part with Load part
thumb
  • For the first part, select extruder 1
thumb
  • For the second part, select extruder 2
  • Export the .gcode file
thumb
  • Load the gcode file into slic3r, connect to your printer and start a first print.
thumb
  • According to your print, modify the relative position of the second extruder from the first extruder in Printer Settings > Extruder 2 > Position
Assembly completed
You printer is now ready to use !
You can either print in dual color or print support material with specific filament such as HIPS or PVA that you can wash off when your print is done !
