ReplicatorG-Skeinforge-RAMPS
Revision as of 15:36, 30 March 2011 by Cloudmaker (talk | contribs)
I built a RepRap Mendel with Wade's Geared Extruder.
I have it working already, but my Skeinforge settings are still way of.
Here will be the place with the tweaks I did to get it going with ReplicatorG.
Software: ReplicatorG 0024 and Skeinforge 0035
Firmware: Teacup Firmware
Hardware: RepRap Mendel with 3 endstops: XMin, YMax, ZMin
Extruder: Wade's extruder
Hotend: Phayzr Hotend (my own quick'n dirty heater design)
File: replicatorg/machines/reprap.xml
  • change settings: TO MAKE THE BAUDRATES match
File: config.h.ramps
  • renamed to config.h
  • softlimits undefined (to make repositioning via the ReplicatorG Controlpanel easy, will be reenabled after everything works)
  • #define BAUD 115200
  • #define XON/OFF
  • ACCELERATION_REPRAP undefined
  • ACCELERATION_RAMPING undefined
  • Stepper settings:
    • #define MAXIMUM_FEEDRATE_X 200
    • #define MAXIMUM_FEEDRATE_Y 200
    • #define MAXIMUM_FEEDRATE_Z 100
    • #define MAXIMUM_FEEDRATE_E 600
    • #define SEARCH_FEEDRATE_X 100 //was50
    • #define SEARCH_FEEDRATE_Y 100
    • #define SEARCH_FEEDRATE_Z 100 ///was 1???
    • #define SEARCH_FEEDRATE_E 50
    • #define E_STARTSTOP_STEPS 1 //this might need to be zero, will try later again
Board: RAMPS
  • Stepper Jumpers:
    • X = 1/16
    • Y = 1/16
    • Z = 1/16
    • E = 1/4
Skeinforge settings:
Activate dimension Set to Relative
ReplicatorG settings:
Prferences: Generate separate Z steps (not sure this necessary) Attention! You ABSOLUTELY need to disable this again if you use ReplicatorG with a Makerbot Thing-O-Matic, it will make the head crash right into the build platform!!!
