ReplicatorG-Skeinforge-RAMPS
I built a RepRap Mendel with Wade's Geared Extruder.
I have it working already, but my Skeinforge settings are still way of.
Here will be the place with the tweaks I did to get it going with ReplicatorG.
Firmware: Teacup Firmware
Hardware: RepRap Mendel with 3 endstops: XMin, YMax, ZMin
Extruder: Wade's extruder
Hotend: Phayzr Hotend (my own quick'n dirty heater design)
File: replicatorg/machines/
- change settings: TO MAKE THE BAUDRATES match
File: config.h.ramps
- renamed to config.h
- softlimits undefined (to make repositioning via the ReplicatorG Controlpanel easy, will be reenabled after everything works)
- #define BAUD 115200
- #define XON/OFF
- ACCELERATION_REPRAP undefined
- ACCELERATION_RAMPING undefined
- Stepper settings:
- #define MAXIMUM_FEEDRATE_X 200
- #define MAXIMUM_FEEDRATE_Y 200
- #define MAXIMUM_FEEDRATE_Z 100
- #define MAXIMUM_FEEDRATE_E 600
- #define SEARCH_FEEDRATE_X 100 //was50
- #define SEARCH_FEEDRATE_Y 100
- #define SEARCH_FEEDRATE_Z 100 ///was 1???
- #define SEARCH_FEEDRATE_E 50
- #define E_STARTSTOP_STEPS 1 //this might need to be zero, will try later again
Board: RAMPS
- Stepper Jumpers:
- X = 1/16
- Y = 1/16
- Z = 1/16
- E = 1/4
Skeinforge settings:
Activate dimension Set to Relative
ReplicatorG settings:
Prferences: Generate separate Z steps (not sure this necessary) Attention! You ABSOLUTELY need to disable this again if you use ReplicatorG with a Makerbot Thing-O-Matic, it will make the head crash right into the build platform!!!
