RepSnapper Manual:Installation
Revision as of 21:59, 19 February 2010 by TheOtherRob (talk | contribs) (Non-Windows Installation)
RepSnapper Manual
  1. download RepSnapper.exe here
  2. run RepSnapper using RepSnapper.exe (you will need OpenGL)
Dependancy Installation
Although RepSnapper is not generally tested outside of window/linux/mac you may be able to get it running on other OS's. To do so you will need the following:
  • gcc and stuff
  • OpenGL
  • SVN
  • libfltk1.1
  • libfltk1.1-dev
  • libglut3
  • libglut3-dev
  • libboost1.37 and -dev (or higher version)
Linux
Debian/Ubuntu
To install the dependencies listed above on Ubunutu or any debian-based linux run the following from prompt: sudo apt-get install build-essential libfltk1.1 libfltk1.1-dev libglut3 libglut3-dev libboost1.38-dev
OS-X
This page is a stub, you can help RepRap by expanding it
RepSnapper Download
You can download the RepSnapper source using svn here by running:
svn checkout http://www.kulitorum.com/RepSnapper/
RepSnapper Installation
Linux
cd Libraries/xml/
make
cd ../../Src/
rm *.o ; make
make
OS-X
