RepRap Version II "Mendel"
Revision as of 20:01, 13 November 2009 by Adrianbowyer (talk | contribs)
The machine on the right is the RepRap printer, which we call "Mendel" after the father of genetics. It's the second, new-improved version: small enough to fit on your desk, but with a print volume large enough for you to make big things (see specifications below). The machine is made up of bits bought in from local suppliers or online, and parts which it can make for itself - all the translucent structural components you can see.
In the picture, behind the machine, you can see the RepRap software which you can use to print your thing. We give this, and the designs for the machine away, free - it's all open source. Though you do have to buy in some standard components from... well, whoever you want... which cost about €350. The idea of getting all the materials and building a machine yourself may seem daunting, but this area of the wiki is dedicated to making the whole process as easy as possible.
You will find directions to all the files in the relevant instructions.
Instructions
Mendel Specifications
The table below outlines the specifications of the machine.
' Metric US imperial
Manufacturer RepRap (or anyone who wants...)
Model Mendel
Technology FFF (Fused Filament Fabrication)/Thermoplastic extrusion
Price of all materials €350 $520
Annual Service Cost Occasional oiling = €5. It can print its own replacement printed parts at material cost. Occasional oiling = $8. It can print its own replacement printed parts at material cost.
Size 500 mm (W) x 400 mm (D) x 360 mm (H) 20” (W) x 16” (D) x 14” (H)
Weight 7.0 kg 15.5 pounds
Build Envelope 200 mm (W) x 200 mm (D) x 140 mm (H) 8” (W) x 8” (D) x 5.5” (H)
Materials PLA, HDPE, ABS & more. Uses ø 3 mm filament. PLA, HDPE, ABS & more. Uses ø 1/8” filament.
Material Cost PLA: €22/kg, HDPE: €11/kg, ABS: €17/kg PLA: $14/lb, HDPE: $7/lb, ABS: $10/lb
Speed 15.0 cm3 per hour solid (test done for PLA, similar for others) 0.92 inch3 per hour solid (test done for PLA, similar for others)
Accuracy Diameter of nozzle 0.5 mm, 2 mm min. feature size, 0.1 mm positioning accuracy, layer thickness 0.3 mm Diameter of nozzle 0.0196”, 0.0787” min. feature size, 0.0039 positioning accuracy, layer thickness 0.012”
Finish Fair Fair
Volume of printed parts to replicate 1110 cm3 67.7 inches3
(With the standard infill settings the 15.0 cm3 per hour solid extrusion rate is equivalent to a built volume rate of 19.0 cm3 per hour.)
Mendel vs. Darwin
Mendel is the latest generation RepRap machine. Mendel supersedes the first version, which we call Darwin. For RepRap Version I "Darwin" instructions follow this link.
Mendel has the following key improvements over Darwin:
  • Bigger print area, smaller machine footprint
  • Improved constraint on the z-axis to eliminate jamming
  • Better axis efficiency
  • Simpler assembly
  • Capacity for tool changing (to follow very shortly)
  • Lighter and more portable
This video illustrates these improvements:
<videoflash type="vimeo">6983001|640|480</videoflash>
For a numerical comparison see this blog post.
