RepRap Version II "Mendel"
Revision as of 21:27, 15 October 2009 by Skinnyed (talk | contribs) (Mendel Specifications)
This section of the RepRap documentation is about building and using RepRap Version II "Mendel". It is under construction.
Instructions
' UK metric US imperial
Manufacturer RepRap
Model Mendel
Technology FFF (Fused Filament Fabrication)/Thermoplastic extrusion
Price £395.00 $630
Annual Service Cost Occasional oiling = £5 Occasional oiling = $10
Size & Wt. 500 mm (W) x 400 mm (D) x 360 mm (H), weight TBC 20” (W) x 16” (D) x 14” (H), weight TBC
Build Envelope 200 mm (W) x 200 mm (D) x 140 mm (H) 8” (W) x 8” (D) x 5.5” (H)
Materials PLA, HDPE, ABS & more. Uses ø 3 mm filament. PLA, HDPE, ABS & more. Uses ø 0.118” filament.
Material Cost PLA: £20/kg, HDPE: £10/kg, ABS: £15/kg PLA: $14/lb, HDPE: $7/lb, ABS: $10/lb
Speed fair, TBC
Accuracy Resolution of nozzle 0.5 mm, 2 mm min. feature size, 0.1 mm positioning accuracy, layer thk 0.5 mm Resolution of nozzle 0.0196”, 0.0787” min. feature size, 0.0039 positioning accuracy, layer thk 0.0196”
Finish fair
Mendel vs. Darwin
Mendel is the latest generation RepRap machine. Mendel supercedes the first version, which we call Darwin. For RepRap Version I "Darwin" instructions follow this link.
Mendel has the following key improvements over Darwin:
  • Bigger print area, smaller machine footprint
  • Improved constraint on the z-axis to eliminate jamming
  • Better axis efficiency
  • Simpler assembly
  • Capacity of tool changing
This video illustrates these improvements:
<videoflash type="vimeo">6983001|640|480</videoflash>
For a numerical comparison see this blog post.
