Build a RepRap
The process of building a fully functional reprap can be broken down into three major areas:
- The software toolchain that generates instructions for the reprap
- The electronics that read the instructions and handle the movement of the reprap
- The mechanical body that does the actual printing
Software Toolchain
The software toolchain can be roughly broken down into 3 parts:
- CAD tools
- CAM tools
- Firmware for electronics
CAD Tools
Computer Aided Design, or CAD, tools are used to design 3D parts for printing.
3D Software
CAD tools in the truest sense are designed to allow you to easily change and manipulate parts based on parameters. Sometimes CAD files are referred to as parametric files. They usually represent parts or assemblies in terms of Constructive Solid Geometry, or CSG. Using CSG, parts can be represented as a tree of boolean operations performed on primitive shapes such as cubes, spheres, cylinders, pyramids, etc. Open source apps that fall into this category would be OpenSCAD and FreeCAD.
Another looser category of CAD tool would be apps that represent parts as a 3D Polygon mesh. These applications are meant to be used more for special effects and artistic applications. They also seem to be a little more user-friendly. Open source apps in this category would be Blender, Google Sketchup and Art of Illusion.
File Formats
Most of the time 3D software apps save their files in a proprietary or application-specific format. There are very few interchangeable CAD file formats. The two most popular and widely used in the real world are STEP and IGES. The mesh-category of CAD tools usually cannot save files in STEP or IGES and thus have poor interchangeability. Once you design a part using those apps, you're usually locked in to that application.
CAM Tools
Computer Aided Manufacturing, or CAM, tools handle the intermediate step of translating CAD files into a machine-friendly format used by the RepRap's electronics.
Software
In order to turn a 3D part into a machine friendly format, CAM software likes to use polygon mesh files. All of the CAD tools above can export parts into a mesh-type file. The reverse is rarely true. In some ways, an analogy would be 'CAM software acts as the compiler for 3D parts'. Not sure what sotware to do this with. I think you use skeinforge or something. Will have to look into this.
File Formats
The main file format use by CAM tools is the STL file. CAM tools convert STL files into Gcode files. The official STL files for Mendel are stored in the reprap subversion repository. To get a copy of these files, run the following commands in ubuntu:
sudo apt-get install subversion svn co https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/mendel/mechanics/solid-models/cartesian-robot-m4/printed-parts/
This will create a directory full of STL files that you can then give to your neighbor that already has a reprap and they can print out the parts for you. You will also notice that this directory contains AoI files. These files are for Art of Illusion. It is the CAD application that was used to design the parts.
Firmware
Reprap electronics are controlled by an inexpensive CPU such as the Amtel AVR processor. Amtel processors are what Arduino-based microcontrollers use. These processors are very wimpy compared to even the average 10 to 15 year old PC you find in the dump nowadays. However, these are CPUs so they do run primitive software. This primitive software they run is the Reprap's firmware.
Of the entire software chain that makes the Reprap work, the firmware portion of it is the closest you get to actual programming. Luckily, there are many people that have done all the heavy lifting already so you don't have to do much or any programming at all. To make the electronics work, you just download the firmware for your controller's CPU. Usually this is done by connecting a USB port to your computer and running an application.
After your microcontroller has its firmware loaded, it is ready to accept G-code files which have the machine-friendly instructions on how to print your part.
Firmware Types
Some of the firmwares used by Reprap electronics are: FiveD, Teacup, and Sprinter.
Electronics
Here is where a bunch of stuff goes that talks about controller boards and G7 and G6 and all the other stuff thats buried in the wiki
Mechanical Body
This is the part of the reprap most people are probably eager to build.
There are around 40 parts in the Mendel that you have to print out from an existing reprap. If you don't have access to another reprap (which is probably 99.9% of the people reading this), you'll have to make those parts by hand using wood or steel I'm guessing. If you don't have a wood workshop or CNC machine, I guess your best bet is to find a local machinist or carpenter that can make them for you.
Unfortunately, most carpenters or machinists will need blueprints to make the parts. At the moment, there are no ready-made blueprints you can download and print out. A print (I've been told they just call them 'prints' in the trade) usually shows the front. top, right, and sometimes isometric views of the part with measurements on it. This is where the reprap project could seriously use some help.
However, to make prints, you'd pretty much have to redraw all the STL files in a 2D or 3D CAD app. If a 3D part is designed in freecad, it can do the projections (prints) for you but you can't put any dimensions on the parts. According to the freecad team, you'd have to export the prints as dxf files, and import them to QCad to add dimensions.
Bill of Materials
Other than the printable portions of the reprap, again, you'll need a spreadsheet listing parts to buy, suppliers, estimated cost, etc.
Building the Body
To build the body, take a look at the STEP file in the source code, look at videos and I think there's stuff elsewhere in this wiki.
RepRap Models
For the full evolution of RepRap models, check out RepRap Family Tree.
Current
The RepRap Mendel now comes in 3 major variants:
- Mendel - The original reprap design
- Prusa - The faster to print, cheaper to build Mendel variant
- Huxley - the somewhat experimental, not-yet fully documented, travel-sized Mendel variant
Legacy
These models are not being developed any more:
Improvements
Mendel design improvements are available on the Mendel Development page.
