RepRapPro Multimaterials
Introduction
This page describes the steps you need to take to build the multi-material and multi-colour version of RepRapPro Ltd's version of RepRap Mendel.
For the most part, the construction is the same as for the single-colour machine, and you should follow the instructions for that through to the end and get your machine working with a single colour/extruder before starting the work on this page.
When you have followed the single-colour machine instructions through to the end, then start...
Step 1 - Installing the slave electronics
...here.
The slave controller is mounted in exactly the same way as the master controller, but on the opposite side of the machine. Mount it with the screw connectors at the back, and the USB connector at the front and the bottom.
Take the insulating tape off the power wires and connect them to the slave controller. Make sure to get the polarity right.
Step 2 - The extruder drives
Step 1: Components
Step 2: Assembly
Start by assembling the geared filament drive.
Take the 20mm M3 hex screw and insert it into the large drive gear. Make sure the flats of the hex head are aligned with the hexagon of the recess. Put the 20mm M3 hex screw with the thread running all the way to the top through the nut then screw on the other parts. The order goes:
- Hex head
- Gear
- 623 bearing
- Hobbed insert
You will notice that the hobbing on the insert is not in its centre. Put the insert on so that the hobbing is away from the gear end and the conical chamfer is against the bearing. After putting the bearing on, but before the hobbed insert, place a small blob of superglue or threadlock on the screw threads, about 5mm from the bearing. Then screw on the hobbed insert.
Do the hobbed insert up tight with your fingers.
Next put a 623 bearing in the back of the drive block as shown. You may need to clean the hole a little. Use a 10mm drill bit twisted carefully in the hole by hand. While you are at it, clean the hole at the other side too.
Push the gear and hobbed insert assembly that you just made into the opposite side of the block to the one that you just put the bearing into. Check that the hobbing is centred where the filament will run by looking in the unoccupied idler bearing hole in the side of the drive block (poke a length of filament down the 2mm hole in the top of the block if you can't tell where this is).
Take the gear and hobbed insert assembly out of the block for the moment.
Mount the block on the motor as shown above using two 16mm M3 cap screws. Put the spacer between the block and the motor. The motor wires are at the back right in this picture.
Fit the idler bearing using the 12mm M3 cap screw as shown (the screw needs no nut to retain it).
Fit the small gear. You may find this easier if you use a sharp blade to put a slight chamfer on the underside of the gear where it meets the motor shaft.
Push the small gear onto the shaft such that its top is flush with the end of the shaft. You may need to tap it with a soft hammer or block of wood - take care, and support the back of the motor shaft as you do this, rather than the motor's body.
Push the gear and hobbed insert assembly into its hole in the block. Rotate the gear as you do this so that it meshes with the small gear on the motor.
Note that the gear and hobbed insert assembly is designed so that the action of driving the filament tends to tighten the hobbed insert on the M3 thread. It can also be easily removed for cleaning when there is no filament in the drive. But when it is operating the filament that it is driving retains it in place by lying in the slight dent formed by the hobbing.
Step 3: The Bowden tube
Don't confuse the PTFE tube (shown) with the shorter translucent heatshrink also supplied with the kit. | |
Item | Quantity |
Tongue (printed) | 1 |
slotted brass retainer | 1 |
PTFE tube | 1 |
Use a sharp blade to trim a few millimetres off the end of the tube at right angles to get a clean square end.
Screw the tube into the brass retainer. Look in the other end (a magnifying glass is useful) to see when it gets to the end of the internal thread, then stop. If you have trouble starting the threading, make a small cone on the end with a pencil sharpener. Don't cut too far - PTFE is very soft. The cone makes it easier to start the thread.
Screwing the tube in will have reduced its internal diameter slightly. Gently twist a 2mm drill by hand in the end of the brass to thin the tube where it is inside the screw thread. If you have a small hand-chuck this is made easier. The picture shows this being done for the other brass connector that you will install on the next page. The method is the same:
Push a short length of 1.75mm build filament down the tube from its free end to clear out any PTFE swarf, and to check the filament moves smoothly.
Push the brass retainer into the drive, and secure it with the printed tongue in the hole above. The thin end of the tongue goes towards the front in the picture at the top of this page, locking the brass retainer in place:
Idler Tensioning
In order to tension the idler mechanism, tighten the two M3 cap screws and nuts mentioned earlier until the point that the drive block has sufficiently flexed that no gap is visible.
Feed a length of filament through the drive by turning the big gear by hand. When you hold the gear still, it should not be possible to pull the filament back out of the drive by hand. If it slips, tighten the two nuts slightly.
