Re-ARM
Release status: Working
[[image:|center|190px]]
Description | LPC1768 for use with RAMPS 1.4
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Summary
Re-ARM is a R3 form factor NXP LPC1768 based controller. It is meant to replace an Arduino mega260.
Software
Smoothieware - see the Panucatt quick start guide.
Marlin - supported in Marlin 2.0
Compatible Shields
RAMPS1.4 is the only known compatible shield.
RAMPS-FD has a mechanical interference problem.
Pinout when used with RAMPS1.4
The LPC1768 has fewer I/O pins than the mega2560 which results in some logical pins no longer available and some logical pins being available on two different pins.
The logical pin numbers in the gallery are Marlin.
* The following pins are NOT available in a Re-ARM system * 7 * 17 * 22 * 23 * 25 * 27 * 29 * 32 * 39 * 40 * 42 * 43 * 44 * 45 * 47 * 64 * 65 * 66 */
/** * special pins * D37 - not 5V tolerant * D49 - not 5V tolerant * D57 - open collector * D58 - open collector * */
* PWMS * * There are 6 PWMS. They do NOT share resources with the system so all 6 are available. * * SERVO2 does NOT have a PWM assigned to it. *
Analog inputs - there are 8 analog inputs on the Re-ARM compared with 16 on the mega2560.
- A0 (T0) - D67 - TEMP_0_PIN
- A1 (T1) - D68 - TEMP_BED_PIN
- A2 (T2) - D69 - TEMP_1_PIN
- A3 - D63
- A4 - D37 - BUZZER_PIN
- A5 - D49 - SD_DETECT_PIN
- A6 - D0 - RXD0
- A7 - D1 - TXD0
D63, D67, D68 & D69 still have analog inputs assigned to them.
D67, D68 & D69 are the only analog inputs that don't require external signal conditioning. All the others have huge (25% & more) spikes.
D67, D68 & D69 are available on the RAMPS board or on the Re-ARM board. The ones on the Re-ARM board have less noise on them. Solder jumpers J7, J9 & J10 select which pins are active. The board comes with the RAMPS pins enabled.
When configured as an analog input, the pins are NOT 5V tolerant. The useable range is 0 - 3.3V.
LCDs
Most LCDs are expected to use the J3 & J5 connectors on the Re-ARM board. J3 is pinned out for the 12 pin Viki2 LCD flat ribbon cable.
The standard SMART LCD adapter can be used to interface RepRap Discount Full Graphic type of controllers. The pinout is different than when used with a mega2560.
- If your LCD requires +5V then you'll need a special EXP1 cable.
- If your LCD uses any of the following signals then you must use J3 & J5:
- - LCD_PINS_D5, LCD_PINS_D6 & LCD_PINS_D7
- - DOGLCD_A0 & DOGLCD_CS
- Starting with MKS, a lot of the LCD displays have the shrouds on the EXP1 & EXP2 connectors rotated 180 degrees from those on the RepRap display. To use the Smart LCD Adapter you'll either need to use a custom cable or CAREFULLY pry up and reverse the connectors on either the adapter (preferred) or the display.
NOTE - The mega2560 pinout used two SPI channels but the Re-ARM only routes one to this adapter. The result is garbage/lines appearing on the RepRap Discount Full Graphic display when the SD card is accessed. Sometimes the garbage/lines remains on the "Print from SD card" submenu screen after the SD card accesses are finished. Marlin 2.0 starting in late 2017 has a software work around for this issue.
Schematic
CROSS REFERENCE: Arduino logical pin & port_pin
* Sorted by Sorted by * Arduino port and then * logical pin by pin * 0_3 D0 0_0 D20 * 0_2 D1 0_1 D21 * 1_25 D2 0_2 D1 * 1_24 D3 0_3 D0 * 1_18 D4 0_4 D24 * 1_19 D5 0_5 D28 * 1_21 D6 0_6 D80 * 2_7 D8 0_7 D81 * 2_4 D9 0_8 D82 * 2_5 D10 0_9 D83 * 1_20 D11 0_10 D38 * 2_12 D12 0_11 D55 * 4_28 D13 0_15 D52 * 1_26 D14 0_16 D16 * 1_27 D15 0_17 D50 * 0_16 D16 0_18 D51 * 1_29 D18 0_19 D56 * 1_28 D19 0_20 D61 * 0_0 D20 0_21 D62 * 0_1 D21 0_22 D48 * 0_4 D24 0_23 D67 * 2_0 D26 0_24 D68 * 0_5 D28 0_25 D69 * 4_29 D30 0_26 D63 * 3_26 D31 0_27 D57 * 3_25 D33 0_28 D58 * 2_13 D34 1_0 D78 * 2_11 D35 1_1 D79 * 2_8 D36 1_4 D77 * 1_30 D37 1_8 D76 * 0_10 D38 1_9 D74 * 1_22 D41 1_10 D75 * 2_3 D46 1_14 D73 * 0_22 D48 1_15 D72 * 1_31 D49 1_16 D70 * 0_17 D50 1_17 D71 * 0_18 D51 1_18 D4 * 0_15 D52 1_19 D5 * 1_23 D53 1_20 D11 * 2_1 D54 1_21 D6 * 0_11 D55 1_22 D41 * 0_19 D56 1_23 D53 * 0_27 D57 1_24 D3 * 0_28 D58 1_25 D2 * 2_6 D59 1_26 D14 * 2_2 D60 1_27 D15 * 0_20 D61 1_28 D19 * 0_21 D62 1_29 D18 * 0_26 D63 1_30 D37 * 0_23 D67 1_31 D49 * 0_24 D68 2_0 D26 * 0_25 D69 2_1 D54 * 1_16 D70 2_2 D60 * 1_17 D71 2_3 D46 * 1_15 D72 2_4 D9 * 1_14 D73 2_5 D10 * 1_9 D74 2_6 D59 * 1_10 D75 2_7 D8 * 1_8 D76 2_8 D36 * 1_4 D77 2_11 D35 * 1_0 D78 2_12 D12 * 1_1 D79 2_13 D34 * 0_6 D80 3_25 D33 * 0_7 D81 3_26 D31 * 0_8 D82 4_28 D13 * 0_9 D83 4_29 D30 */
