R 360 Development
Revision as of 23:30, 27 December 2014 by Glenn (talk | contribs) (-tags)
R_360 Documentation
R-360
R-360 is the first polar printer by Replicator Warehouse.
R-360 - Open - development
All new developments will be part of the new R-360 Open. http://reprap.org/wiki/R_360_Open
Nickname
Prusa R-360
This project is merging the ideas of the great Reprap Prusa 3 with the R-360 to achieve the ultimate 3D printer. The plastic parts are designed to be minimalistic in term of printing time. The 3D files will be completely configurable so you can choose your printing volume and rod, bolt thicknesses. The default size will be 300mm disc and 400mm height printing volume. But you can easily set values from 100mm to 2000mm or more. Any combination will be possible. (like 200mm disc with 500mm height or the other way around.
Features
We aim to create a pro printer, however it will be possible to use cheaper alternatives, cutting costs.
Large printing volume
100mm to 2000mm depends on configuration
High speed printing
Heated Bed
Modern 32bit Controller
Dual Extruder
Lead-screws
Planning to support 3rd party 3D scanning
Configurable Printing Volume
Configurable Rods and Bolts
Files
Coming soon!
