RUG/Pennsylvania/State College/Software/Parts/Dual Extruder
Revision as of 20:27, 17 January 2012 by KtripPSU (talk | contribs) (Progress Blog)
The quest for dual extrusion
This page is to document the ongoing project of developing a dual extrusion system (software, firmware, g-code, electronics, extruders). The idea to pursue a dual extrusion system came about from [[this]] thingiverse entry by user ScribbleJ. The idea of a dual extruder system is to create parts using two different materials (differing colors, water soluble support material, etc.). The difficulty comes in the fact that no aspect of a reprap is designed for such a set up, and until recently, no dual extrusion system was commercially available. On this page I will update with the information required to complete a dual extrusion system (or however much I have figured out as the project progresses), as well as keep a blog of my progress. I will upload patches and firmware updates as they are created in hopes of collaboration on the project.
Progress Blog
1.17.12: It's a new semester, meaning another attempt at Dual Extrusion. After my short battle with it last semester, I'm back and ready to tackle it once and for all. If MakerBot can produce a commercially successful dual extrusion system, I should be able to figure it out with a little help from my colleagues here at Penn State.
We've made a few decisions as to the configuration of the system. We are going to be using RAMPS electronics, a shield that attaches to an Arduino unit, to drive the machine. Tentatively, the firmware used will be Marlin, a derivative of sprinter but with a few upgrades that make it a step above. All of this will be mounted on a Mondo RepRap, allowing for more room and hopefully some really big and cool prints.
Changes of the day:
Under configuration.h
  1. define EXTRUDERS 1 becomes #define EXTRUDERS 2 (to specify 2 extruders instead of 1)
  1. define MOTHERBOARD 7 becomes #define MOTHERBOARD 33 (to load the pin configuration for RAMPS 1.3 and 1.4)
I commented this line #define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200*8/3,760*1.1} and uncommented this line #define DEFAULT_AXIS_STEPS_PER_UNIT {80.3232, 80.8900, 2284.7651, 757.2218}
This was to bring the parameters to what is specified for the SAE Prusa specs, I'll need to check on these for our current machines.
10.18.11: Firmware night, and I must say, it's going to be quite the task. I spend the night familiarizing myself with the firmware language and editor, as well as locating the sections of code that will need modification. The actual firmware rework will have to wait though, as I need to see exactly what sort of code will be sent to the machine with regard to tool (extruder) selection. This will happen as soon as I can learn Skeinforge and begin generating the code that will be sent to the machine.
10.11.11: Today marks the beginning of the project. I assessed the feasibility of the project and determined which software, electronics, and hardware to use. The selections can be found in each of the respective sections below.
Aspects
Hardware
Electronics
Firmware
Software
Code
