RUG/Pennsylvania/State College/RepSnapper
Revision as of 12:47, 13 January 2012 by Jfo5039 (talk | contribs)
Notes
Currently, we are using an old version of RepSnapper which we refer to as "RepSnapper Zero". It saves to XML files, and does not list "Logick's Algorithm" among the shrink algorithms. This version seems to predate the git repository, and thus far I am unable to find source code for it. We use it instead of RepSnapper beta (1.1.x) because we find it generates better gcode, and does not crash as frequently.
However, we have put effort into being able to compile RepSnapper beta ourselves, in hopes of being able to tweak/revert the gcode generation and fix other minor issues.
The earliest code I have found is the old subversion repository, from which I can get a current checkout but not a clone of version history. This code is not as old as our version of RepSnapper, as it does list Logick's Algoritm. However, it does list the "Much slower, perfect, small details" which ours does. This shrink option corresponds to a "ShrinkNice" function in stl.cpp, which uses a "Generic Polygon Clipper" library (gpc.h, gpc.cpp) written by Alan Murta of the Advanced Interfaces Group at the University of Manchester. The earliest commits in the git repository, after the initial import, modify the code to remove the gpc files. I'm not sure why this code was dropped-- perhaps because its license limits it to non-commercial use?
Compiling on Ubuntu Linux
One of our machines runs Ubuntu linux 10.10. Here is how we installed repsnapper 1.1.x:
Note: The machine is not connected to the internet, so packages are transferred using Synaptic's "Generate Download Script" option on a separate computer.
The following packages were required, as listed by the readme:
build-essential fluid libgtk2.0-dev libfltk1.1 libfltk1.1-dev libglut3 libglut3-dev libboost-thread-dev libboost-system-dev libconfig++8-dev libconfig8-dev
Note: Initially I neglected to install libgtk2.0-dev, which caused confusing build errors that the packages "gtk+-2.0" and "gthread-2.0" could not be found. Installing libgtk2.0-dev fixed the problem (gtk+-2.0 is satisfied by libgtk2.0-dev, and gthread-2.0 is satisfied by libglib2.0-dev, which is a dependency).
The codebase was downloaded using Git on a windows pc:
git clone git://github.com/timschmidt/repsnapper.git -b repsnapper-1.1.x
The code was compiled:
cd repsnapper/src
make
The resulting executable "repsnapper" was then moved to ~/toolchain, and a desktop shortcut created.
Compiling on Windows MinGW
Notes
 * This process is fairly involved.
 * The resulting executable requires a number of dynamic link libraries.
 * According to the MinGW documentation, it would have been better to install libraries into /mingw instead of /usr/local where possible. (eg. using make --prefix=/mingw)
 * In the MinGW shell, /mingw/* corresponds to C:\Path\to\MinGW\* and /usr/local/* corresponds to C:\Path\to\MinGW\msys\1.0\local\*
Install MinGW
 1. Install MinGW 20110802 (mingw-get-inst-20110802.exe from http://sourceforge.net/projects/mingw/files/Automated%20MinGW%20Installer/mingw-get-inst/mingw-get-inst-20110802/mingw-get-inst-20110802.exe/download)
   * I installed to C:\PROGRAMS\MinGW. Path shouldn't matter as long as there are no spaces.
 2. Open a MinGW Shell
Install fltk library
 1. Download and extract fltk-1.1.10 (http://www.fltk.org/software.php?VERSION=1.3.0&FILE=fltk/1.1.10/fltk-1.1.10-source.zip)
 2. $ cd /c/path/to/fltk-1.1.10-source/fltk-1.1.10/
 3. $ ./configure
 4. $ make
 5. $ make install
 6. $ cd FL/
 7. $ make install
Install lua library
 1. Download and extract lua-5.1.4.tar.gz (http://www.lua.org/ftp/lua-5.1.4.tar.gz)
 2. $ cd /c/path/to/lua-5.1.4/
 3. $ make mingw
 4. $ make install
Install boost-build engine
 1. Download and extract boost_1_47_0.zip (http://sourceforge.net/projects/boost/files/boost/1.47.0/boost_1_47_0.zip/download)
 2. $ cd /c/path/to/boost_1_47_0/tools/build/v2/engine
 3. $ ./build.sh mingw
 4. $ cp bin.ntx86/*.exe /usr/local/bin
Install luabind library
 1. Download and extract luabind-0.9.1.zip (http://sourceforge.net/projects/luabind/files/luabind/0.9.1/luabind-0.9.1.zip/download)
 2. $ cd /c/path/to/luabind-0.9.1
 3. $ cp -r luabind /usr/local/include
 4. $ b2 --toolset=gcc link=static variant=release -sBOOST_ROOT=../boost_1_47_0/ -sLUA_PATH=/usr/local
 5. $ cp bin/gcc-mingw-4.5.2/release/link-static/libluabind.a /usr/local/lib
Install boost libraries
 1. $ cd /c/path/to/boost_1_47_0/
 2. $ b2 --toolst=gcc link=static threading=multi variant=release system filesystem
 3. $ b2 --toolset=gcc link=shared theading=muli variant=release thread
 4. $ cp bin.v2/libs/thread/build/gcc-mingw-4.5.2/release/threading-multi/libboost_thread-mgw45-mt-1_47.* /usr/local/lib/
 5. $ cp bin.v2/libs/system/build/gcc-mingw-4.5.2/release/link-static/threading-multi/libboost_system-mgw45-mt-1_47.a /usr/local/lib/
 6. $ cp bin.v2/libs/filesystem/build/gcc-mingw-4.5.2/release/link-static/threading-multi/libboost_filesystem-mgw45-mt-1_47.a /usr/local/lib/
 7. $ cp -r boost/ /usr/local/include
Install GLUT
 1. Download and extract glutdlls37beta.zip (http://www.opengl.org/resources/libraries/glut/glutdlls37beta.zip)
 2. $ cd /c/path/to/glutdlls37beta
 3. $ mkdir /usr/local/include/GL
 4. $ cp *.h /usr/local/include/GL
 5. $ cp *.lib /usr/local/lib
 6. $ cp *.dll /usr/local/bin
Install libconfig
 1. Download and extract libconfig-1.4.8.tar.gz (http://www.hyperrealm.com/libconfig/libconfig-1.4.8.tar.gz)
 2. $ cd /c/path/to/libconfig-1.4.8/
 3. $ ./configure
 4. $ make
 5. $ make install
Install GTK+
 1. Download and extract gtk+-bundle_2.16.6-20100912_win32.zip (http://ftp.gnome.org/pub/gnome/binaries/win32/gtk+/2.16/gtk+-bundle_2.16.6-20100912_win32.zip)
 2. $ cd /c/path/to/gtk+-bundle_*_win32
 3. $ cp -r bin/* /usr/local/bin
 4. $ cp -r lib/* /usr/local/lib
 5. $ cp -r include/* /usr/local/include
Build repsnapper
 1. Obtain the repsnapper source from the repository:
 2. You'll also need the windows Serial libraries from:
   http://svn.kulitorum.com/RepSnapper/Libraries/Serial/
   Put them in repsnapper_1_1/src/Serial
 3. cd /c/path/to/repsnapper_1_1
 4. Add the following to the Makefile above "# Linux":
 # MinGW
 ifeq ($(UNAME),MINGW32_NT-6.1)
   GTK_LIBS=`pkg-config --libs gtk+-2.0 gthread-2.0`
   GTK_CFLAGS=`pkg-config --cflags gtk+-2.0 gthread-2.0` -DHAVE_GTK
   INC=$(GTK_CFLAGS) -I/usr/include -I/mingw/include -I/mingw/include/GL -I$(LIB_DIR) -I$(LIB_DIR)/vmmlib/include -I/usr/include/boost -I/usr/include/lua5.1 -I/usr/local/include
   INC+=-I$(LIB_DIR)/polylib
   LDFLAGS=$(GTK_LIBS) -L/usr/lib -L/usr/local/lib -L/mingw/lib -lfltk -lfltk_gl -lfltk_forms -lglut32 -lopengl32 -lglu32 -lboost_thread-mgw45-mt-1_47.dll -lboost_system-mgw45-mt-1_47 -lboost_filesystem-mgw45-mt-1_47 -lws2_32 -llua -lluabind -lgdi32 -lole32 -luuid -luser32 -lcomctl32 -lkernel32 -lconfig++
   LDFLAGS+=-L$(LIB_DIR)/polylib -lpolylib
   TEST_LDFLAGS=-lboost_unit_test_framework
 endif
 5. make
Run Repsnapper
This compiled copy of repsnapper needs the following dynamic link libraries:
 /usr/local/bin:
   glut32.dll
   libconfig++-9.dll
 /usr/local/lib:
   libboost_thread-mgw45-mt-1_47.dll
 /mingw/bin:
   libgcc_s_dw2-1.dll
   libstdc++-6.dll
As well as the following GTK+ libraries (should be available if you have the GTK+ runtime installed, but can also be found in /usr/local/bin)
 freetype6.dll
 libatk-1.0-0.dll
 libcairo-2.dll
 libexpat-1.dll
 libfontconfig-1.dll
 libgdk-win32-2.0-0.dll
 libgdk_pixbuf-2.0-0.dll
 libgio-2.0-0.dll
 libglib-2.0-0.dll
 libgmodule-2.0-0.dll
 libgobject-2.0-0.dll
 libgthread-2.0-0.dll
 libgtk-win32-2.0-0.dll
 libpango-1.0-0.dll
 libpangocairo-1.0-0.dll
 libpangoft2-1.0-0.dll
 libpangowin32-1.0-0.dll
 libpng14-14.dll
 zlib1.dll
Changes when building Repsnapper 1.0.x
These instructions can be used to build RepSnapper 1.0.x instead of 1.1.x, with the following changes:
  • Don't use a modified 1.1.x Makefile; start with the 1.0.x Makefile and modify it as described above.
  • Change the following line in file.cpp (line 227):
 std::string directory_path = path.branch_path().native_directory_string();
to this:
 std::string directory_path = path.branch_path().string();
A download for a windows build of repsnapper that worked as of 1/12/11 can be found here File:PSURUGrepsnapper.zip.
TODO
I'd like to get rid of some of the dynamic library requirements.
It should be possibly to statically link libboost_thread with a modification to the Makefile as per https://svn.boost.org/trac/boost/ticket/4878
It should be possible to remove the libgcc and libstdc requirements by using the flags -static-libstdc++ -static-libgcc in the Makefile, but this currently causes problems, likely because some of the other dlls themselves have dynamic links to those libraries.
Statically linking GTK+ would be the most significant, but I'm not sure how hard this would be.
Compiling libconfig does produce libconfig++.a, but this doesn't get linked in statically for some reason; not sure why.
Will need to compile glut instead of using a binary distro to get it to link statically.
