RUG/Pennsylvania/State College/Printers/PSU Unit Rainbow
Revision as of 19:52, 4 December 2012 by Djg5125 (talk | contribs) (X Carriage)
This printer is currently under construction starting in the Fall 2012 semester. It is an [OHM] model developed by the reprap PSU community. Its progress and pictures will be posted here as it is constructed as a resource for the group members and the community to see the printer being constructed and hopefully give more insight to the building of an [OHM] printer.
Build Members [Greg Mann] [Alex Blenheim ] [Mallory Guarino] [Dan Guy] [Alex Kasinec]
This printer is part of the [PSU] reprap group
Operating Specifications
Name Status Design Electronics Firmware Extruder Temperature Comments
Rainbow Rainbow Under Construction Ohm RAMPS
Progress
11-2-12 We have almost finished assembling the x-axis carriage and we are waiting on a few parts to finish. We have mounted the z-motors and are ready to mount the x-motor and y-motor as soon as we get the parts needed. After the carriage is finished we hope to print out more parts for the bed of the printer as well as mounting the x-axis carriage.
10-21-12 All of the X axis parts are printed and waiting to be assembled. Our next task is to install the smooth rods associated with the X axis. Also, get the printer ready to be mounted with electronics and motors.
Printer Components
Below is a list of all parts that will need to printed for this specific printer, this table can also be found on the [OHM] page. Also included in this table is an inventory column to help the group keep track of what needs to be printed.
Frame and Z Axis Parts
Quantity File-Name Comments Diagram Part Progress
6 Camiel_frame_vertex_6off Alternative part by Camiel Camiel frame vertex 7off.JPG Printing Complete
2 z-prusa-motor-mount_2off Pm-z-motor.jpg Printing Complete
2 z-bar-top-clamp_2off Z-bar-top-clamp 2off.JPG Printing Complete
4 prusa_bar-clamp_2off Pm-bar-clamp.jpg Printing Complete
8 y-bar-clamp_8off Y-bar-clamp 4off.JPG Printing Complete
1 y-idler-bracket_1off Y-idler-bracket 1off.JPG Printing Complete
1 y-motor-bracket_1off_mod3-15 Modified by PSU Reprap Collective Y-motor-bracket 1off mod3-15.JPG Printing Complete
Y Carriage Parts
4 bed-spring_4off Bed-spring 4off.JPG Printing Complete
1 OpenY_8mm Belt Harness_1off Open Y by Buback, modified by PSU Reprap Collective 8mm Belt Harness 1off.JPG Printing Complete
2 OpenY_8mm Crossbar Mount_2off Open Y by Buback 8mm Crossbar Mount 2off.JPG Printing Complete
2 OpenY_Arm 90 - 180_2off Open Y by Buback Arm 90 - 180.JPG Printing Complete
1 OpenY_arm45 Open Y by Buback Arm 210.JPG Printing Complete
2 OpenY_Undercarriage_Bracket_1off Open Y by Buback OpenY Undercarriage Bracket.JPG Part Needed
X Axis Parts
4 pla_coupling_nophead-1piece_4off Alternative part by Nophead Pla coupling nophead.JPG Printing Complete
2 x-180-z-bearing-plate_2off X-180-z-bearing-plate 2off.JPG Printing Complete
2 PSU_x_vert_sideplate_360_end_2off Alternative part to x-ver-drive-side-plate-360-end_2off.stl PSU x vert sideplate 360 end 2off1.JPG Printing Complete
2 x-360-z-bearing-plate_2off X-360-z-bearing-plate 2off.JPG Printing Complete
2 x-360-z-bearing-plate-mirror_2off X-360-z-bearing-plate-mirror 2off.JPG Printing Complete
1 xaxis-motor-bracket_1off Alternative part by Rhys-jones Xaxis-motor-bracket 1off.JPG Printing Complete
4 x-bar-clamp-m3_4off X-bar-clamp-m3 6off.JPG Printing Complete
4 x-bar-clamp-m4_4off X-bar-clamp-m4 4off.JPG Printing Complete
1 x-end-bracket_1off X-end-bracket 1off.JPG Printing Complete
4 x-vert-drive-nut-trap_4off X-vert-drive-nut-trap 4off.JPG Printing Complete
4 x-vert-drive-side-plate-180-end_4off X-vert-drive-side-plate-180-end 2off.JPG Printing Complete
2 x-axis-side-plate-nut-jig_2off X-axis-side-plate-nut-jig 2off.JPG Printing Complete
X Carriage
Two major issues affected the Open-X carriage: carriages occasionally "walk" up off the tracks, and inconsistent spacing of the undercarriage bracket occasionally allowed the extruder to move/twist laterally. Both of these issues were minimized through modifications by user Joe Bartolai. The OpenX Arm was shortened and an offset was added so that the bearing attached to it is centered on the rail. The OpenX undercarriage bracket was also modified by making the angle steeper where the lower bearings contact the rail and by increasing the spacing where the undercarriage bracket attaches to the carriage. Part models will be added soon.
1 OpenX_Carriage_1off Open X by Buback OpenX Carriage 1off.jpg Printing Complete
1 OpenX_Undercarriage_Bracket_1off Open X by Buback OpenX Undercarriage Bracket.JPG Printing Complete
1 OpenX_arm_PSU_1off Open X by Buback Modified by PSU Reprap Collective OpenX arm PSU 1off.jpg Printing Complete
1 OpenXY_bracket OpenXY bracket.jpg Printing Complete
Extruder
Currently not included in STL zipfile
1 HerringboneDrivenGear Alternative part by Rhys-jones HerringboneDrivenGear.JPG Printing Complete
1 HerringboneDriveGear Alternative part by Rhys-jones HerringboneDriveGear.JPG Part Needed
1 Gregs_accessible_wades_v6 Alternative extruder by Greg-Frost Gregs accessible wades v6.JPG Part Needed
1 Gregs_accessible_wades_idler Gregs accessible wades idler.JPG Part Needed
Electronics
We will be installing RAMPS onto this printer...more information to follow, for now check out this link to our class electronics page Electronics and this link for RAMPSRAMPS link
