RUG/Pennsylvania/State College/Printers/BioFab@Home
Revision as of 20:49, 9 December 2014 by Gmy5011 (talk | contribs)
BioFab@Home
Color: Acrylic
Extruder: Syringe
Temperature: -
Design: Fab@Home
Electronics: RAMPS
Firmware: Marlin
Main | About | Research | Gallery
Introduction
This is the page for the State College Rep Rap User Group's (SCRUG) Fab@Home 3D printer that is being converted to print a variety of biological materials. The printer was originally constructed in accordance to the original Fab@Home Model 1 design, incorporating the original electronics and single-syringe tip extruder. The build progress was documented here.
Log
Date Modification / Problem
6/13/2014 Up and running very smoothly! Double linear bearings on Y fixed slop on the axis.
6/9/2014 Tested with linear bearings on all axes. Good movement, but needs double bearings on Y for proper stability.
04/22/2014 Extruder tested and working. Can both extrude and retract water
03/24/14 Successful conversion to RAMPS 1.4 electronics with 1/8 step settings and 300 mm/sec speeds.
02/24/14 Beginning conversion to RAMPS 1.4
