RUG/Pennsylvania/State College/Mullis
Revision as of 00:24, 5 December 2011 by Rbdschur (talk | contribs) (Mullis 1)
Mendel
Release status: In Development
An idea for a cheap PCR Machine that can be easily made from a Prusa Mendel.
GPL
Overview
The Mullis (named after Kary Mullis, winner of the Nobel Prize for PCR)is a project of the State College Reprap Users Group. It is an open source, RepRap based PCR machine. (For more on PCR, see http://en.wikipedia.org/wiki/PCR ). The design uses a readily available tray for PCR, which is carried back and forth between two heated containers. It is easily converted from an Open Hybrid Mendel, or a Prusa Mendel (link).
This is a work still in progress, of which there are two versions.
Mullis 1
1. In one (Mullis 1), the print bed is removed, and two smooth rods are added in its place. On these rods rest two heated plates, into which the sample tray fit. Each plate is heated to a different specific temperature, and held constant. The tray is moved back and forth between each plate via the x and z axes.
Parts Printed Parts (coming soon)
Extra Vitamins Mullis 1 Assembled
Mullis 2
In Mullis 2, the tray is raised and lowered by a winch system into two separate heated water baths. The tray moves on an extended x axis between the two baths.
Extra Vitamins - Two smooth rods, approximately 24 inches in length - Two independently heated, temperature controlled water baths. The baths need to be significantly larger than the tray.
PCR (Polymerase Chain Reaction)
PCR (Polymerase Chain Reaction) is a DNA replicationg technique. A DNA sample is set in a solution containing primers and nucleotides (A,T,C,G). The DNA is heated up quickly, so that it denatures (untwists) and then separates. It is then annealed (cooled), allowing the primers to attach to the open halves of the DNA strands. Next, an enzyme (Taq polymerase) extends the strands by allowing complimentary nucleotides to become attached to each open strand of DNA. This results in two separate but identical strands. The process is repeated until millions of copies of the sample are made.
