RUG/Pennsylvania/State College/Electronics/Gen3/Firmware
Revision as of 21:51, 2 May 2011 by Joshj (talk | contribs) (Current Fimware)
Mendel Firmware (Techzone Remix)
Current Fimware
These files are identical to the firmware found here: media:OneWireA-DFirmware.zip With the exception of configuration.h, which is modified as follows:
OneWireA-DFirmware (Source):
#define ENDSTOPS_MAX_ENABLED 0
// This is for Darwin.
#define X_STEPS_PER_MM   10.047
#define Y_STEPS_PER_MM   10.047
#define INVERT_Y_DIR 0
#define Z_STEPS_PER_MM   805.030
// parameters for the Bath U. mendel prototype
#define X_STEPS_PER_MM   13.333333
#define Y_STEPS_PER_MM   13.333333
#define Z_STEPS_PER_MM   944.88
Bestmobocode:
#define ENDSTOPS_MAX_ENABLED 1
#define X_STEPS_PER_MM   20.094
#define Y_STEPS_PER_MM   20.094
#define INVERT_Y_DIR 1
#define Z_STEPS_PER_MM   1610.6
#define X_STEPS_PER_MM   26.666666
#define Y_STEPS_PER_MM   26.666666
#define Z_STEPS_PER_MM   1889.76
For the most part, this seems to be a modified version of the (old) vanilla reprap code. There's a page describing the modifications required to use the Techzone thermocouple boards here:
