RAMPS 1.6
Revision as of 08:54, 8 February 2022 by Dust (talk | contribs) (Warning update)
Version specific info
RAMPS 1.7 | RAMPS 1.6 | RAMPS 1.5 | RAMPS 1.4.4 | RAMPS 1.4 | RAMPS 1.3 | RAMPS 1.2 (RAMPS 1.2 old) and older
RAMPS 1.6
Release status: Working
RepRap Arduino Mega Pololu Shield Arduino MEGA based modular RepRap electronics.
The RAMPS 1.6 is the second RAMPS iteration released by BIQU/BIGTREETECH. It replaces the original green power connector with a pair of screw terminals, adds a larger heatsink over the MOSFETS, and has a larger bed MOSFET. It maintains the surface-mounted fuses and flush MOSFETS of the RAMPS 1.5.
Also, the positions of the D1 and D2 diodes have been swapped from the positions in RAMPS 1.4, the D1 diode is now the diode closest to fuse F2. The same is true for RAMPS 1.5, also manufactured by BIQU/BIGTREETECH.
Board
Wiring guide
Design files
PCB Ramps 1.6 GitHub repository
Firmware
Old Marlin v1 Firmware Firmware provided by designer
Schematics
For pdf versions see: Repository at GitHub
Warning
Some third party versions of this board have a design flaw. The 5v line from J2 through to the 5v pin in the servo plugs are shorted to GND. Connecting the jumper J2 will connect VCC directly to GND and destroy the voltage regulator on the mega2560 board.
One brand of board that is known to have this issue is labeled "ZYLtech Texas USA" "RAMPS 1.6"
This is the logo from this board.
The issue was investigated and found to be a design flaw in the PCB, where by the J2 5v pin is connected to the GND plane.
