Prusa i3 Rework Motor assembly
Revision as of 05:09, 21 March 2014 by Dark Alchemist (talk | contribs) (Y-axis)
Introduction | Bill of materials | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly
X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Marlin Firmware
Z-axis
Needed parts :
  • Endstop Z Holder
  • 2x Coupling 5x5
  • 2x NEMA 17 motor
  • 1x Endstop
  • 2x Treaded rod M5x300 mm
  • 8x M3x14 mm screw
  • 2x M3 nut
  • 8x Ø3 mm washer
Step 1
Insert a threaded rod M5x300 mm at the half length of a coupling 5*5 and fix it with two grub screws. Do the same for the other rod.
Step 2
Thread each threaded rod in X End Idler and X End Motor M5 nut at half length.
Threading two M5 rods on X-axis.
Step 3
Take the single frame assembly and place two NEMA 17 motor with their supply wires against the aluminum frame. Optional feature: cut the supply wires at half-length and insert them through the dedicated hole. If you do not want to solder the wires, you can place them through the bottom notch.
Step 4
Fix an endstop to the Endstop Z Holder with two M3x14 mm screw, two Ø3 mm washers (on the rear) and two M3 nuts. Slightly tighten it at half height. The adjustment will be made in the following.
Z-axis endstop assembly on the Z Endstop Holder.
Step 5
Place the Endstop Z assembly on the Z Axis Bottom left and fix it with left motor with three M3x14 mm screws and three Ø3 mm washers.
Fix right motor with three M3x14 mm screws and three Ø3 mm washers.
Z-axis endstop and motor assembly.
Step 6
Fix both coupling at both motor shafts with grub screws. Make sure to place a grub screw in the face of the flat of the shaft.
Tighten both grub screws with an Allen wrench.
Z-axis coupling assembly.
Y-axis
Needed parts :
  • 1x NEMA 17 motor
  • 1x Endstop
  • 1x GT2 pulley
  • 5x M3x14 mm screw
  • 2x M3 grub screw
  • 2x M3 nut
  • 5x Ø3 mm washer
Step 1
Thread two M3 grub screws on a GT2 pulley. Slide this pulley on the motor shaft and fix it. Make sure to place a grub face to face with the flat of the shaft.
Assembling GT2 pulley on motor shaft.
Step 2
Place and fix the previous NEMA 17 motor on the Y Motor with three M3x14 mm screws (on the Kysan 1124090 stepper motor M3-14mm is 1.5mm-2mm too long and you will need to cut off 2mm from the screws) and Ø3 mm washers. Place supply wires down.
Place and fix an endstop with two M3x14 mm screws and two Ø3 mm washers. The endstop have to be on the bottom of the groove.
Assembling Y-axis motor and endstop.
X-axis
Needed parts :
  • 1x NEMA 17 motor
  • 1x GT2 pulley
  • 3x M3x14 mm screw
  • 2x M3 grub screw
  • 3x Ø3 mm washer
Step 1
Thread two M3 grub screws on the GT2 pulley. Slide this pulley on the motor shaft and fix it. Make sure to place a grub screw face to face with the flat of the shaft.
Step 2
Place and fix the previous NEMA 17 motor on the X End Motor with three M3x14 mm screws and Ø3 mm washers. Place supply wires down.
X-axis motor assembly.
Mechanical frame assembly
Needed parts :
  • Y-axis assembly
  • Single frame assembly
Step 1
Insert the single frame assembly between both M10 nuts and Ø10 mm washers which are on the Y-axis assembly. The Y-axis assembly has to be inserted on both single frame grooves. Moreover, the Y Motor has to be placed nearest you.
Step 2
Adjust the single frame assembly to have 245 mm from the front of the aluminium frame to the external side of an Y Corner. Make sure that this dimension is verified on both left and right sides of the heated bed. This setting allows you to maximize printing workspace.
Connecting Y-axis and X and Z-axis assembly (.
Step 3
Strongly tighten both couple of M10 nuts and Ø10 mm washers on the single frame assembly. Make sure that the mechanical frame is stable.
