Prusa i3 Rework Bill of materials
Introduction | Bill of materials | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly
X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Marlin Firmware
Printed parts
Extruder
Smooth and threaded rods
- 2x Smooth rod Ø8x320 mm
- 2x Smooth rod Ø8x350 mm
- 2x Smooth rod Ø8x370 mm
- 2x Threaded rod M5x300 mm
- 4x Threaded rod M10x210 mm
- 2x Threaded rod M10x380 mm
Mechanical parts
Heated bed
Electronics
Screws, nuts and washers
If using the SainSmart endstops then you will need 2 M3 flat head screws per endstop that uses the bottom 2 holes to attach it (example the X-Idler) as the SainSmart endstops has a bad design flaw that gives absolutely zero clearance for the two lower screws as the wiring harness is too close to the pcb and over laps some of the 2 bottom open holes (wiring harness points downward at a 90 degree angle). With these you can bend up the wiring harness, ever so slightly and be extremely cautious and gentle, to get the flat head M3 screw heads to go under the harness. Once they are under the harness proceed to attach with the nuts but remember the heads MUST come into the holes from the side with the wiring harness due to the mentioned lack of any clearance.
If you are having a hard time find the M3x60mm screws you can use 1/8 inch toggle bolts http://www.homedepot.com/p/Unbranded-1-8-in-x-2-in-Zinc-Plated-Toggle-Bolt-with-Mushroom-Head-Phillips-Drive-Screw-4-Pieces-00444/202187084 and remove the screw in piece from the toggle side (easily comes out) and it fits perfectly on the extruder. Use springs and a washer and you are set though I did use a Dremel to remove the threads for 1/2 of the bolt.
Aluminium frame
- 1x Single frame
- 1x Heated bed mount
