Prusa Mendel
Revision as of 18:43, 22 October 2010 by Sikko (talk | contribs) (Bill of Materials: Re-inserted known info)
Prusa Mendel
Release status: unknown
Prusa Mendel is simpler remix of normal Mendel.
Prusa Mendel is simpler remix of normal Mendel. I want to use bushings instead of regular bearings, right now, my prototype is using two bearings, one for X and one for Y axis. Actual State is, that I have whole machine up and running, with my DIY PLA bushings. Its pretty smooth. <videoflash>tyVM3-v84I0</videoflash>
Development
The Prusa Mendel is on hosted github: http://github.com/prusajr/PrusaMendel
You can sign up for github for free and fork the project to begin working on it.
History
Bill of Materials (without extruder)
The Prusa Mendel BOM is included in the Prusa Mendel README on GitHub here: Prusa Mendel Bill of Materials
(in works, not complete yet) 80x M8 nut Fastener 76x M8 washer Fastener
3x 608 Bearing		Bearings
6x frame-vertex	RP
2x coupling		RP
3x endstop-holder	RP
1x x-carriage		RP
1x x-end-idler		RP
1x x-end-motor		RP
2x z-motor-mount	RP
4x belt-clamp		RP
8x bar-clamp		RP
2x rod-clamp		RP
1x y-motor-bracket	RP
2x pulley		RP
3x pla-bushing		RP
Printed Parts
Printing a Prusa on a Mendel
An easier option then individually printing each part if you are printing Prusa on a RepRap Mendel is the pre-assembled build file containing the Prusa parts. With this option you only need to print the Mendel plate and 3 of the PLA bushings to get a complete Prusa Mendel:
Printing a Prusa on a Makerbot
There are also pre-assembled build files available to fit your Makerbot's build area (download using right click => save as)
Printing a Prusa on anything else
Last but not least, if you have a machine that doesn't fit into any of the previous options all the .stl files necessary to print a Prusa Mendel are available on the PrusaMendel Github where you can download them and print them individually.
Assembly
This page is a stub, you can help RepRap by expanding it
This needs some work by someone familiar with Prusa, for now though you can at least use the images bellow to identify each part in the design and then try every possible combination until it works.
IF YOU FIND THE WORKING PERMUTATION OF PARTS PLEASE POST ANY AND ALL PRUSA MENDEL ASSEMBLY INFORMATION HERE.
X-Carriage
X-End-Motor
Parallelnes of rods is ensured by the teardrop type of holes for rods plus securing bolts from bottom (there is nut bracket inside the part). By pushing the rods upside, they will self center.
X-End-idler
Universal Bar-Clamp
Frame-vertex
I use my mod of Vik's vertexes, slimmer, same sturdy as original :-) http://www.thingiverse.com/thing:2003
See Also
